01-08-2013, 07:06 PM | #1 |
Inline six spark arrestor
Anyone know if the spark arrestor is available somewhere. I cant seem to locate it in any parts houses. See pic below. I am trying to build the line that goes from the air cleaner spacer to the side of the valve cover. I think its called a spark arrestor????
01-08-2013, 07:38 PM | #2 |
Re: Inline six spark arrestor
I think that you are looking for crankcase ventilation (PCV) early style....Ruggles
01-08-2013, 07:59 PM | #3 |
Maybe? Someone else called it a spark arrestor in another thread. I do have the standard PCV valve in the back of the air cleaner. Than I have just a rubber hose that goes from the front side of the vale cover to the Air cleaner spacer. Now Im switching to a Offset air cleaner like the one above and all that I see have that line with what looks like a fat PCV valve inline. ??
01-08-2013, 09:57 PM | #4 |
Heres a better picture I found from another thread. Now Ive seen it been called a flame supressor, Breather filter etc.... Anyway Ill need to source as much of this setup as I can to run my Offset filter.
01-09-2013, 12:29 AM | #5 |
Probably wrecking yard.
'67 GMC 2500, 292, 4spd, AC |
01-09-2013, 01:18 AM | #6 |
Theoffset air cleaners and parts are tough to find. I saw a complete offset air cleaner set up on the parts board pretty cheap. I think it had this piece. A few years back I bought an offset air cleaner for $50 but it was missing the spacer and this breather. I got lucky and found one on the parts board for $15.
Posted via Mobile Device |
01-09-2013, 05:24 AM | #7 |
I have the arrestor filter piece. I believe the six cylender arrestor is bigger than ones used iv v8's. Will post pics if you are interested.
01-09-2013, 08:27 AM | #8 |
01-09-2013, 02:36 PM | #9 |
i have these 2. The smaller mouth one is from a 68-72 v8 and the larger mouth is from a 67 v8 and 67 and up line 6 with optional closed pos vent. I believe the larger one is what you are looking for. I may have the rubber hoses as well but would have to look. I dont have the cleaner, spacer or the metal tube that comes out of the valve cover. Removed this so long ago that i have no idea what happened to them. Rod.
01-09-2013, 05:28 PM | #10 | |
01-30-2013, 11:54 PM | #11 |
I couldn't find the hoses. Did you still want the arrestor?
01-31-2013, 04:22 PM | #12 |
Thanks, but I ended up brabbing a whole setup in the meantime
01-31-2013, 04:57 PM | #13 |
no worries. just checkin.
01-31-2013, 05:20 PM | #14 |
thanks for your trouble tho!
01-31-2013, 07:53 PM | #15 |
1969 Custom 30 wrecker
I just came across one of these if you still need one. From a 67 Chevy that had the oil bath air cleaner. All original with GM markings on hose.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
01-10-2019, 03:41 PM | #16 |
01-11-2019, 08:43 PM | #17 |
5 Year Old Thread Dredged up yet Again...
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
