01-08-2013, 10:29 PM | #1 |
TBI in a 66 swb
I am putting a tbi 350 with a 700r4 in my 66, getting close but ran into a problem, any one know what gas tanks fit from other trucks or cars into my frame with as little modification as possible. I want to put it back behind the axle where the spare tire used to hang. Keep in mind the fuel injection pump and sending unit either have to fit into the new tank or has to work with my 87 tbi
01-08-2013, 11:02 PM | #2 |
Re: TBI in a 66 swb
ive fitted a suburban tank on a 63 between the rails,measure up a 87 burb.
01-08-2013, 11:16 PM | #3 |
Moderator
Re: TBI in a 66 swb
Check the dimensions on the 91-96 Caprice/Roadmaster tanks. They are plastic so they won't rust. The 91-3 ones will have the correct pump for your TBI setup. The 94-6 ones have the high pressure pump for MPFI so you would have to swap it.
01-08-2013, 11:51 PM | #4 |
Re: TBI in a 66 swb
Bobdrake.com has a 1949-52 Chevy tank with 2 holes for new or old sending units. They also offer a sending unit that you can add your own pump to. Lakeroadster installed one in his truck with minimum changes.
65 short step edited by staff |
01-09-2013, 12:23 AM | #5 |
Re: TBI in a 66 swb
I will have to try the 89 suburban tank next but my 87 must have been a 40 gallon, it is huge.
My u-pull and pay has one 93 caprice and two 94's no road masters, I will hit them up tomorrow and see if they poked holes in it. |
01-09-2013, 01:25 AM | #6 |
60-66 Nut
Re: TBI in a 66 swb
The '87-'91 K5 Blazer tanks might be a little smaller than a Suburban tank, and will have the correct pump.
01-09-2013, 01:29 AM | #7 |
Re: TBI in a 66 swb
I dont think he believed me when I told him the K5 blazer tank fits. Hmm
01-09-2013, 10:06 AM | #8 | |
Re: TBI in a 66 swb
I used a new 84 blazer tank but had to modify it for the in tank fuel pump, here is a link...... http://kieth.smugmug.com/Trucks/66-G...0096&k=WfTFcBh |
01-09-2013, 12:38 PM | #9 |
Senior Car Nut
Re: TBI in a 66 swb
IMO, the neat thing about the caprice tanks (and others) is that the filler exits to the rear.
check out various make/model/year tank dimensions here (scroll down and click on the manufacturer): http://www.gastanks.com/GAS-TANKS/departments/1/ sorry, they don't seem to have the plastic one mentioned by jayoldschool, but the link can be used to find tanks with the dimensions you need. most guys seem to use the blazer tank but it hangs down kinda low
Larry Last edited by fleetsidelarry; 01-09-2013 at 12:53 PM. |
01-09-2013, 01:49 PM | #10 |
Re: TBI in a 66 swb
I heard the early Ford Falcon tanks fit nicely.
01-09-2013, 05:19 PM | #11 |
Re: TBI in a 66 swb
I PUT A 55CHEVY CAR TANK IN HAS 30 OHM SENDING UNIT ALSO TRIM A LITTEL ON LEFT UPPER FRAM RAIL USED 55 CHEVY MOUNTING STRIPS ALSO
01-09-2013, 07:53 PM | #12 |
Re: TBI in a 66 swb
i used a 90 s10 blazer tank , 0-90 ohm sender
and correct pump and pressure for tbi Posted via Mobile Device
///Relaxed Atmosphere |
01-09-2013, 09:27 PM | #13 |
Re: TBI in a 66 swb
Jimmy your the one that told be the rear cross member fits just fine, I will try to steal yours but you seen how big my tank was, 40 gallon might be guessing on the low side.
Any how I am tracking down a k5 blazer one. The junk yard punches holes in all the gas tanks so there are not going to work. Going to see what I can find . I looked under an s10 blazer and it looked to be shaped like a saddle bag style. I only looked at one it might have been a spare tank but I will keep up the hunt. Another good question might be how to mount it, is it safe to drill through the seam on the edges and mount by those or is it best to just find a way to use the straps from some thing to hold it up? |
01-09-2013, 09:51 PM | #14 |
Re: TBI in a 66 swb
s10 blazer tanks are almost square and come in 13 and 20 gallon
http://www.autopartswarehouse.com/de...cid=productads i got mine off ebay for 90 new shipped my 63 has a jegs fuel cell that fits perfect inside the rails , and then i used a external pump
