Weiand 177
Just got blower installed over the weekend, The 177 just fits under the hood with the air cleaner and man is this thing fun to drive.
![]() Join Date: Oct 2006
Re: Weiand 177
That's cool!
![]() Is it on a small block? Did you have to move the engine back so that it didn't hit the radiator? Are you running an electric fan? Short or long water pump? Sorry for all the questions, but I was thinking about doing this on a truck at some point aloso. |
Re: Weiand 177
Its on a 327, didn't have to move anything Just use the blower with the long nose and I used the long water pump which I already had on there everything bolted right up. Just had to get a drop base air cleaner so the filter would fit. Oh and still using the stock fan setup with a spacer.
![]() Join Date: Mar 2011
Re: Weiand 177
My build thread - Devastation and Reform http://67-72chevytrucks.com/vboard/s...d.php?t=567131 |
Re: Weiand 177
This is the only pic I got while installing it.
Re: Weiand 177
Still have he stock 3.08 gears outback and the thing just wants to spin the tires
Re: Weiand 177
Theres one of those for sale on craigslist in my area for $1700... good deal?
Comes with 2 pulleys
-CJ- 69 GMC stepside 350 370HP TH350 4:11's 8MPG and proud! |
Re: Weiand 177
I think $1700 is a good deal, they are about $2400 new, I paid $2300 for mine used with carb and msd btm box new.
![]() Join Date: Oct 2005
Re: Weiand 177
My 383 has the 142 on it and it would be better with the 177.......which will probably make some good boost on a 327.....what is your static compression ratio? I modified my drop base filter to go even lower so I could get a 4" element on it. I think the 177 is about 2" taller than the 142.......what size filter you running?
....and your are right......these little street blowers are fun and I love having it UNDER the hood. ![]()
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
Re: Weiand 177
my compression ratio is 9-1 I am running about a 1 1/2 inch aircleaner. I went with the 177 just incase I go with a stroker motor down the road.
