![]() Join Date: Aug 2007
radiator and heater hose size questions
Looking to buy the Billet coolent hose clamps from Eddie motorsports and just seeing if anyone knows the upper and lower radiator hose sizes? The heater hoses and 5/8 and 3/4, I just dont have a spare hose laying around to measure. Any help would be greatly appreicated.
Scotts72C10 |
Old member
I just measured my water pump outlet for the bottom hose and it's 2" and the hose looks to be 2 1/2 outside. So I would say 2 1/2" clamp should work.
The top hose measured 1 3/4" inside and 2" outside so a 2" should be fine for them. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: radiator and heater hose size questions
Thanks for doing that, much appreicated
Scotts72C10 |
Old member
No problem I had mine all took a part to fix some leaks.
