Old 01-09-2013, 05:11 PM   #1
SunSoaked
SunSoaked's Avatar
Twin Stick rail mods
I'm going to twin stick my 205. I plan to fab the shifter and linkage myself. I know I need to modify (lengthen?) the indexing "slots" on the shift rails. Has anyone done this or have instructions on how to do it? I don't want send them to ORD and pay $85 for a simple mod.
I will be using a mill, not the angle grinder
SunSoaked is offline   Reply With Quote
Old 01-09-2013, 05:14 PM   #2
snj8198
snj8198's Avatar
Re: Twin Stick rail mods
I think ORD has a guide on how and where to grind the shifter rods. Check their site. I used to have a template for it but not sure where it got put.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 01-09-2013, 05:17 PM   #3
Redcap
http://www.pirate4x4.com/forum/gener...ick-cheap.html
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-09-2013, 06:04 PM   #4
SunSoaked
SunSoaked's Avatar
Thanks guys. That actually looks pretty easy.
Old 01-09-2013, 06:38 PM   #5
Redcap
It is. Having access to a mill makes it even easier.
Old 01-09-2013, 08:04 PM   #6
kwmech
I've done dozens of them, you don't even have to touch the lower rail. The purpose of the twin stick is to be able to do a front drive (dig) only. So with that, all you have to do is modify the 2wd or top rail to neutralize while in 4wd either high or low. This way also prevents from putting the rear into low and front into high or visa/versa
