Old 06-09-2003, 01:19 PM   #1
Mike Culpepper
Red
Mike Culpepper's Avatar
Vintage air glove box?
ANyone have a pic of the vintage air glove box installed? I am CLOSE to getting my system charged, but was wondering if the plastic glove box fit inside the dash cut out for the glove box or outside the dash cut out?
Mike
'72 Cheyenne LWB 350/350
"The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game).
Mike Culpepper is offline   Reply With Quote
Old 06-09-2003, 01:40 PM   #2
Frank_Zeller
Frank_Zeller's Avatar
I put in an Old Air setup. I bet it's the same glove box liner. The new glove box liner goes in from the front. You screw though it. SO inside the dash cut out. There should be little dimples for where the screws go.
69 SWB C/10 5-6 drop 700R4
69 Firebird Convert 455 4 spd
70 Torino GT Convert
Austin-Texas
Frank_Zeller is offline   Reply With Quote
Old 06-09-2003, 04:53 PM   #3
Mixup
I just installed my Vintage Air glovebox. Just like Frank said slide it in from the front and it sits inside. All you have to do is drill some holes. It's not much of a glovebox, just fills up the hole.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 06-09-2003, 05:23 PM   #4
Mike Culpepper
Red
Thanks!
Hey, Mixup, Did you install the whole system yourself?
If ,so, I had a question about the larger a/c hose that goes from the compressor to the evap. (can't remember if it is the suction or discharge line????). If I use the V.A. clips that are for securing the air cap to the rectangular part of the firewall cover, about 1/2 of the crimped part of the hose is inside the air cap and 1/2 out side and the gromet is REAL tough to get positioned. I was thinking about tossing the clips, pushing the air cap back further toward the fire wall, and securing it with small screws, so that most of the crimped part of the a/c hose will be on the outside of the air cap........what do you think? Did you have similar problems?
Mike
Old 06-10-2003, 12:01 PM   #5
Mixup
Mike my whole system is in except the hoses. A friend of mine owns a Radiator-A/C shop and he is making the hoses for me this week. I'm at work when I get home and look at the directions I'll let you know.
1969 Z28 engine
Turbo 350
Old 06-10-2003, 12:03 PM   #6
Mixup
By the way most of the ones I've seen had screws on theat cap and no clips.
1969 Z28 engine
Turbo 350
Old 06-10-2003, 02:32 PM   #7
Mike Culpepper
Red
Mixup,
Thanks for the reply.
The more I think about it, my cover is probably going to have screws too.
Old 06-10-2003, 03:10 PM   #8
tom hand
CCRider
tom hand's Avatar
I used the clips and had no problem...PM me your e-mail and I will send you pics when I get home.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 06-10-2003, 03:47 PM   #9
Mike Culpepper
Red
Tom,
you've got a PM
Mike
Old 06-10-2003, 06:11 PM   #10
tom hand
CCRider
tom hand's Avatar
Sent the pics but it showed me how good my memory is...lol. After looking at them I see I used the clips and some self tapping screws to keep the thing from popping off
Olive Branch MS
Old 06-13-2003, 05:29 PM   #11
Mixup
Got my A/C hoses made yesterday and the Vintage Air unit works great. 33 degrees at the center vent.
1969 Z28 engine
Turbo 350
Old 06-13-2003, 05:56 PM   #12
Mike Culpepper
Red
I'm gettin mine charged tomorrow!
Mike
Old 05-26-2015, 07:38 PM   #13
elf w/capital T
Re: Vintage air glove box?
Mike, im jealous. Im still trying to get mine to pop in right. Right now I only have four of the bottom j nuts. Ugh. Tight fit!
elf w/capital T is offline   Reply With Quote
Old 05-26-2015, 07:51 PM   #14
leftybass209
leftybass209's Avatar
He may not get your message, he hasn't logged in since Nov, 2013.
leftybass209 is offline   Reply With Quote
Old 05-26-2015, 07:57 PM   #15
serge
serge's Avatar
VA glove box install inside opening. Tight fit but box very pliable (installed and removed 5+/- times, UGH!).
Good luck,
Serge
General Contrucktor
serge is offline   Reply With Quote
Old 05-26-2015, 07:58 PM   #16
clemsonteg
I slid mine in with the end closest to the center first and slid it past it's position so I could swing in the side closest to the passenger side. I installed the VA box the same way the factory box was installed in my truck, with the bottom portion being sandwiched between the lid hinge and the lip for the dash and the sides and top are behind the lip for the dash. I didn't have to drill any holes and I used the factory hardware except for the 2 side screws which were missing anyways. I snapped a few pics. Hope it helps.
clemsonteg is offline   Reply With Quote
Old 05-26-2015, 07:59 PM   #17
clemsonteg
Side shot
Old 05-26-2015, 08:00 PM   #18
clemsonteg
Sorry for 3 posts, the site is only taking 1 picture at a time from my iphone. Top of the box
