Old 01-09-2013, 06:34 PM   #1
t5noel
Quadrajet question
Hey Guys, I'm a neophyte when it comes to carburetors. I am renovating a 1974 GMC C1500 pickup. I'm putting a new stock 350 from Summit in it. A friend gave me a quadrajet 17083226 3202 FKC. It is for an 81-86 Chev/GMC/Truck BOP. It has the electric choke. Can I use this on my truck? Don't laugh too hard if I'm out in left field just educate me a little please. Thanks!
t5noel is offline   Reply With Quote
Old 01-09-2013, 07:02 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Quadrajet question
It will work just fine. Run a hot wire to it that is only hot when the ignition is on, and then it will work as long as it is adjusted properly. If you have an air choke, you'll have to make provisions to block off the port at the manifold. Other than that, you should be fine. It will bolt right up.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is online now   Reply With Quote
Old 01-09-2013, 07:21 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Trash.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-09-2013, 07:49 PM   #4
Damon23
Damon23's Avatar
My quadrajet is acting up. I've had a few on some of the Fbody cars I've had. After a rebuild from someone that knows what they are doing they are fine. But, if you dont know anyone that is good with them, get something different. I've always had luck with edelbrocks. I think that is what I'm going to have to do here next week.
Damon23 is offline   Reply With Quote
Old 01-09-2013, 08:42 PM   #5
Dead Parrot
Assuming the carb looks in decent shape, just get a stock GM manifold (non-egr unless you have to worry about emissions) and give it a try. The GM manifold won't need any adapters and should be cheap to get from a salvage yard. If the carb works at all, it should get you through the rest of the restoration project. Once you get the rest of the truck fixed up, then you can always re-think the carb and manifold question. Until then, save your money.
Dead Parrot is offline   Reply With Quote
Old 01-09-2013, 08:56 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
yes it will work fine, I just did this on my 1976 new engine. As Steve said its a one wire hook up, just make sure it only has power while ignition is on. Also what intake manifold are you going to install?
I went with this qjet from summit
http://www.summitracing.com/parts/JET-36001
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 01-09-2013, 09:09 PM   #7
OutlawDrifter
the q-jet is a great carb, it will give you the best balance of economy and performance. if the fuel was drained and it was stored properly, chances are you can just throw it on and go. cliff's high performance sells a great kit for 35 bucks to go through the carb if you need to tear into it...don't be afraid of the q-jet, most people don't like them because they have more parts than most carbs.
1991 Z/28, 6.0L/T56
Instagram @aceshighspeedshop
Old 01-09-2013, 10:37 PM   #8
Kryptonite
ive been told a q-jet is great and doesnt need constant adjustment like a holley.
But beware that they have a cork float that after time will get saturated and sag causing you to waste 30 to 60% of fuel. They are also known for " quadro bog " but if you can find somone to adjust your butterflies they are dependable.
Kryptonite is offline   Reply With Quote
Old 01-10-2013, 01:55 AM   #9
ol'blazer
ol'blazer's Avatar
In my opinion Holley is the worst carb when it come to adjustment, I have used many q jets over the years and they are one of the most reliable carbs you can get!
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 01-10-2013, 10:38 AM   #10
Corts60
Just here to tinker
Corts60's Avatar
Originally Posted by INSIDIOUS '86 View Post
Trash.
He asked if it will work, not your opinion. If you have no helpful input for the OP, do not post at all.
Old 03-28-2013, 09:16 PM   #11
t5noel
I do have a mechanic friend very familiar with the quadrajet. He has rebuilt it for me and I have it mounted on the new engine.
Old 03-29-2013, 10:58 AM   #12
Keckdl
Keckdl's Avatar
I think you will love it if it has a good rebuild and tuned correctly. As said before it has the best economy/ performance out there for a carb. I get better milage with my Qjet than most people do with their fuel injections on similar set ups.
Dan
83 Chevy K10 Scottsdale, ZZ4, TH700r4, 4.10, 33"
Keckdl is offline   Reply With Quote
