Old 01-09-2013, 09:07 PM   #1
scabby9
scabby9's Avatar
engine code on my 87 ?
Pretty new to the group but i was wondering if anyone can help me with an engine code. I can't find any info on the FBC at the end. The guy i bought it off said it was a crate engine he bought off another guy. any ideas?
scabby9 is offline   Reply With Quote
Old 01-10-2013, 11:31 AM   #2
Ski-me
Ski-me's Avatar
Re: engine code on my 87 ?
Found a little help......
http://www.nastyz28.com/chevy-engine-code-stampings.php
K - St. Catherines, Ontario Plant
07 - July
08 - July 8th
FBC - ????
EBC - ????
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 01-10-2013, 11:58 AM   #3
Keith Seymore
Keith Seymore's Avatar
07 - July
08 - July 8th
FBC - ????
EBC - ????
Thanks for posting that.
I can't help on the specific code (FBC) but recognize it as the three letter broadcast code in the assembly plant (sometimes known as the "pick code"). This code allows the assembly operator to choose the correct engine configuration without having to remember the specific part number.
As such, though, since it has an assembly plant code on the block I highly doubt it is a "crate" motor - unless the builder used a production block as a core for their build.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-10-2013, 05:54 PM   #4
scabby9
scabby9's Avatar
i'll have to get the block number as soon as the snow melts i guess. The local dealership told me they can get all the info with that number it's just that the truck is snowed in at the moment.
Is it possible that there could be a code for engines sold from the dealer as crate engines? the last 3 letters are to determine the type of vehicle it belongs in i believe.
I have googled it and there are a few other forums with the same question but no answers. Thanks again for your help.
Old 01-10-2013, 07:22 PM   #5
Keith Seymore
No. The codes are to help the assembly line operator. If the engine is a crate or service replacement put in at the dealership there is no need for the code.
Further detail: let's say you order a 350 cu in engine. There is one base part for a 350, but it proliferates on Auto vs manual trans, a/c vs no a/c and California emissions vs Federal.
So there would be eight part numbers within that one engine family (there would probably be this many variations for v6, for 305 cu in, for 454 cu in and diesel as well):
12345678 350 cu in manual no a/c Fed
12345679 350 cu in manual w a/c Fed
12345680 350 cu in auto no a/c Fed
12345681 350 cu in auto a/c Fed
12345682 350 cu in manual no a/c Calif
12345683 350 cu in manual a/c Calif
12345684 350 cu in auto no a/c Calif
12345685 350 cu in auto a/c Calif
An assembly plant broadcast code would be assigned to each part number:
TAA 12345678 350 cu in manual no a/c Fed
TAB 12345679 350 cu in manual w a/c Fed
TAC 12345680 350 cu in auto no a/c Fed
TAD 12345681 350 cu in auto a/c Fed
TAE 12345682 350 cu in manual no a/c Calif
TAF 12345683 350 cu in manual a/c Calif
TAG 12345684 350 cu in auto no a/c Calif
TAH 12345685 350 cu in auto a/c Calif
So the operator goes over to a bay that is full of racks and racks of engines (probably more than you've ever seen in one place in your entire life). You can tell him which one to choose, via the build manifest, and he can remember that he needs an "AF", instead of trying to remember 123455683, or manual/AC/California emissions, since he will do this nearly 500 times in one day.
K
1979-1986
1986 - 2019
Old 01-16-2013, 09:21 AM   #6
Keith Seymore
K
Pick the right engine: This happens to be a passenger car plant (Tarrytown) but will give you a visual of what I mean:
K
1979-1986
1986 - 2019
Old 01-16-2013, 11:49 AM   #7
rfmaster
rfmaster's Avatar
Keith
What a wonderful, historic photograph!!! Thank you for sharing! Due to rampant disappearance of manufacturing jobs in USA very few of us (still) know what a production line should look like!
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
