Old 01-09-2013, 11:02 PM   #1
47AD
Rear Motor mount crossmember from 1954 or 1st series 1955
I'm considering an idea for my '47 AD pickup that I thought I'd toss out there. Don't know that I'll do it but wanted to think this through. If I understand correctly, a 1963 Chevy pickup bell housing for a 4 speed trans will bolt up to a small block Chevy. The rear motor mounts for the bell housing show they fit years 1954 - 1984. What I was wondering is if the rear motor mount crossmember from a 1954 or 1955 1st series AD fit in a 1947 AD? If it did, would the 1963 Chevy pickup bell hosing mount on the crossmember as a simple bolt on?
Dan
47AD is offline   Reply With Quote
Old 01-12-2013, 09:55 PM   #2
2manyprojects
2manyprojects's Avatar
Re: Rear Motor mount crossmember from 1954 or 1st series 1955
It will work. I am getting ready to do this swap myself. 50 GMC , 55.1 cross-member, 65 bell housing. The cross-member took me awhile to find so keep that in mind if your in a rush to do it.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
Old 01-12-2013, 10:44 PM   #3
47AD
Thank you for the reply on this. I wasn't sure if anybody knew for sure or not. I was hoping that some truck builders out there doing frame swaps might have a crossmember they'd be willing to part with from their old frame. I'm not in a rush to do this so I'll start looking here locally first.
Dan
Old 01-12-2013, 10:57 PM   #4
2manyprojects
No problem, They are out there just a little harder to find because it was 1 year only.
