Old 01-09-2013, 11:40 PM   #1
Tinsmith
71 tie rod taper?
Hi guys
I recently switched to 71 drop spindles, and as you guys know the inner tie rods are different. I went with the CPP billet tie rod sleeve so the conversion sleeve is not an option. I have searched locally for a 71 center-link to no avail. which leads me to my next question I am looking to purchase a tie rod taper reamer to fix the current one I have now. Does anybody know the taper of tie rod, there seems to be a few different GM tapers. Any help would be appreciated.
Thanks Jon
Tinsmith is offline   Reply With Quote
Old 01-10-2013, 09:57 AM   #2
Longhorn 70
Longhorn 70's Avatar
Re: 71 tie rod taper?
subscribe
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-10-2013, 10:58 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Hotchkis sells an aftermarket centerlink.
Personally I would use the conversion tie rod sleeve.
63-70 conversion spindles would have eliminated all these issues.
I found out the hard way, by using 71-72 spindles also.
Never again.
Good luck with your search.
Keith
Convert to disc brakes.
Old 01-10-2013, 09:10 PM   #4
Tinsmith
I contacted hotchkis about their center link but they do not sell it separately only in a kit with the control arms. And from what I can understand is that they use the 67-70 tie rods to. Here's the story as to why I switched, my truck is originally a 71 2wd my brother-inlaw (The P.O.) put it on a 4wd frame and jacked it up. He got bored with it and I traded him for it, only after he sold the original frame. I found a 68 frame and have been putting it back together. So I wanted to get it all back to the same year. Hence the situation I am in. Sorry for the long story. I guess I will take it to a machinest and see if they can fix it?
Jon
