Old 01-10-2013, 12:41 AM   #1
BIGTEN
BIGTEN's Avatar
Engine troubles??
Truck was running fine couple weeks ago and all of a sudden it barely stays running, I have to keep my foot on the pedal to keep it goin and when you let off it shakes and sputters and is extremely quiet. I changed all the vacuum lines to the carb but still the same, did the starting fluid trick to see if it got sucked into anything but nothing. This is extremely baffling?? I took it out the other day to see if I had fixed anything and went down the street it wont go past 35 and the auto trans stays in gear for about a minute and then shifts over. I can have the pedal to the floor and its like it doesn't want to move, but it does if that makes any sense. Its a 350 sb all stock with all the smog setup with a q-jet 350 trans if that helps. Also when you move the gas pedal in the right spot just a touch the carb sounds like a sucking vacuum dont know if this is normal or its just the engine getting its air?
BIGTEN is offline   Reply With Quote
Old 01-10-2013, 12:57 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Engine troubles??
I can't remember, do 350 trans have a vacuum modulator? When you describe the trans holding 1st gear for a long time that sounds exactly like the modulator is not getting vacuum. And that would also mean you have a vacuum leak down there if the line is ruptured.
Old 01-10-2013, 12:57 AM   #3
86c20
86c20's Avatar
what year is your truck? my 86 did the same thing come to find out it has a computer controleed dizy i swaped it out and no more problem
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 01-10-2013, 03:09 AM   #4
bk2life
possible accelarator pump dead. and with the cold weather its having a hard time tryin to run.
not going over 35mph would make sense of not shifting to well either.
alot of suckin vacuum noise, that one has me puzzled. vacuum line popped off maybe?
post more info
bk2life is offline   Reply With Quote
Old 01-10-2013, 10:35 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
yup I'd check the intake vac line to mod valve
mine was acting up all of a sudden,the hose bit came off
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 01-10-2013, 01:44 PM   #6
mrolds88
Is it making a whistling sound all the time? Is it idling fast? Those two would indicate a vacuum leak. I would double check the timing. Since a LOT of squarebodies used that plastic and aluminum cam gear from the factory, it almost sounds like the timing chain jumped to me. Easiest way to check it is to turn the engine over until the tming mark lines up on the timing cover and pull the distributor cap. If it doesn't line up, that would be the first suspect. Also while you have the cap off, you can check just how sloppy the timing chain is. All you have to do is rotate the crank backwards until the distributor moves. Shouldn't have more than about 5 degrees.
mrolds88 is offline   Reply With Quote
Old 01-10-2013, 06:22 PM   #7
BIGTEN
BIGTEN's Avatar
Its a 79 square, I changed the vac mod not too long ago so probably not that. I'll check under there for ruptured lines and such.
Old 01-10-2013, 06:54 PM   #8
bilfman
bilfman's Avatar
Brake booster vac leak?
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 01-10-2013, 07:06 PM   #9
BIGTEN
BIGTEN's Avatar
Ok looked at the tranny all the lines are good, check the carb lines (replaced all of them) thats good. So turned the truck on after looking and it was not idling right so I gave it a quick rev and it sound like air in the lines just escaped, truck was running good, took it around the block (hard/ stalling shifting went away) pulled it into the drive way let it sit a little and back to the terrible idle and now the oil pressure gauge is going crazy, it fluctuates all the way down to 0 and back up the 30 like its having a seizure.
Old 01-10-2013, 07:19 PM   #10
BIGTEN
BIGTEN's Avatar
Booster line looks cracked and old and jiggled it around and it leaked. So is the plastic peace coming out of the booster replaceable or does the whole thing need to be replaced?
Old 01-10-2013, 07:24 PM   #11
bilfman
bilfman's Avatar
Hit a wrecker and grab the grommet, fittings and hoses. Replace the whole thing.
But that said i think you may have bigger issues my friend. Fluctuating oil pressure is no good. I know this juvenille but make sure your oil is up, starving the oil pump pickup can cause the fluctuation in pressure. But hearing that the engine isn't running well it may well be a larger internal issue.
Old 01-10-2013, 09:35 PM   #12
Zebb
Zebb's Avatar
Float stuck maybe or some crud got sucked into the carb?
Zebb is offline   Reply With Quote
Old 01-10-2013, 10:36 PM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
a thought
when i did mine carb lines i had a air leak
I had to tap the tube back into the carb housing
meaning the small tube sticking out the side of the carb,pulled out when pulling off the old tubes
looked ok,but had to tap them in
John
Old 01-10-2013, 10:54 PM   #14
ZMAR
ZMAR's Avatar
My 84 does the exact same thing. I.e. sounds like it has a HUGE cam, won't idle, and won't go over 30. I have to hold the throttle halfway down to even start it. The only difference is it is overheating. I have no idea wth is going on!
71 c10 swb
ZMAR is offline   Reply With Quote
Old 01-12-2013, 01:13 PM   #15
BIGTEN
BIGTEN's Avatar
Ok this morning changed the booster check valve, grommet and line put a quart of oil cus it was low. It acts like its normal starts up fine idles a little fast but something is still wrong. At this point I have no clue?
Old 01-12-2013, 08:49 PM   #16
BIGTEN
BIGTEN's Avatar
Finally figured it out, had some vacuum hoses flip flopped to a thermal check valve for emission control!! Now she runs better than ever.
Old 01-12-2013, 08:59 PM   #17
Corts60
Just here to tinker
Corts60's Avatar
Well done!
