![]() Join Date: Dec 2012
Parking brake rod??
Hey guys I was replacing my parking brake cables from front to back and found the rod on the passenger side is not removable. Or at least I couldn't tell how to take it apart to replace the cable... Can anyone tell me how to go about it? Change the whole rod? cut and re weld? Etc?
Thanks in advance Scott Posted via Mobile Device
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: Parking brake rod??
Scott, If you don't have manuals yet this link will help a lot.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 01-10-2013 at 02:46 AM. Reason: wrong link |
Tim the link is to my thread. The rod is a solid rod with non removable caps. I will check the manual but I physically looked at it and I am a little puzzled that chevy would do that.
Fixed the link
Chassis Service Manual Fig 64 on page 274 should give a break down on what you are looking at. IIRC the cable threads through the rod and guides before it is clipped to the axle cables.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Ok the attached picture is the rod on the passenger side I need to remove
IIRC it just comes out from the front after the cable is pulled.
Pull the cable, unhook the guide and remove the rod from the front.
On the ends of the cable there are stops pressed on. The stop on one side is smaller and will slip through the guide, then the guide will slip off the rod.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Lee that's my problem....I didn't check the other end.
Thanks guys now I understand how to take it off. I bought the complete e brake cable kit from Inline. Posted via Mobile Device
