Tv cable?
Been doing lots of reading about tv cable options for the 700r4 going into my 66. Im a little confused because Bowtie Overdrive gives a spring in their kit and says it needs to be installed or tranny will die. Is this only because of the geometry of their kit? I know my 700r4 works fine as I was able to drive it a good ways before pulling it. Am I gonna kill the trans if I just put the Edelbrock bracket on the throttle to correct geometry? Besides being able to slightly change shift behavior what else does the bowtie kit accomplish?
Who Me?
Re: Tv cable?
All I know about the TV cable is, if you set it up wrong, you will smoke your tranny!!
If your unsure how to do it, find someone that does!!
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
Re: Tv cable?
I used a bowtie overdrive set up on my 48 coupe.....no problems....I did use spring
Re: Tv cable?
Pretty certain I can set tv cable once geometry is correct! My concern is why bow tie says the spring is needed with their kit or tranny will die!
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Tv cable?
You might try calling Bowtie Overdrives and ask them. I'm sure there is a good reason for it.
![]() Join Date: May 2012
Re: Tv cable?
I've got dish network (lol)
John Posted via Mobile Device |
Re: Tv cable?
Hahaha
Re: Tv cable?
the reason for the spring is like insurance.
It's there to cover your butt ![]() In most cases the spring is worn out & unless you remove it and measure it you will never know. They have has seen to many transmissions burn up due to the spring alone, so they offer the spring & say you MUST change it... so you do just that change it out. This way you are 100% sure that the spring in your transmission is good. Scott
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi, ![]() ![]() All my Google Albums |
Re: Tv cable?
Scott!! You the man! Exactly the info I was looking for! Thanks!
Jimmy |
