Old 01-10-2013, 03:18 PM   #1
SunSoaked
SunSoaked's Avatar
205/AA adapter help.
Got the AA adapter yesterday to mate my 205 to the NV4500 and have a question.
1) Is there supposed to be a seal or seal housing that goes on the input shaft? Otherwise will the oil leak from the bearing and be contained inside the adapter?
The adapter is good quaility but the instructions dont say anything about it.
SunSoaked is offline   Reply With Quote
Old 01-10-2013, 03:51 PM   #2
s_nova69
Re: 205/AA adapter help.
dirrty larry will chime in soon. On my 700r4 i missed the seal that went in the end of the coupler and it filled my tcase with atf. I bet there is supposed to be one there. Just call AA and ask them
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 01-10-2013, 04:05 PM   #3
stanton77
Yes you are missing the seal housing. The seal housing retains the bearing in the case along with sealing the input shaft. You can see it in the pic I have of one of my t-cases, this a NP203 but it uses the same style seal housing.
You can also see it on this 205 inside the adapter.
72' Family Truckster
stanton77 is offline   Reply With Quote
Old 01-10-2013, 04:28 PM   #4
SunSoaked
SunSoaked's Avatar
I have a figure 8 205 and it didn't have anything (sealwise) on the input shaft other than the funky cast iron adapter/mount that went around it.
I have heard the term "sealed" and "unsealed". Maybe this is what it refers too? I assume that's why the unsealed had issues with trans fluid ending up in the t-case?
Old 01-10-2013, 04:49 PM   #5
stanton77
The transfer case you have pictured is not a figure 8 style transfer case. The transfer case you have pictured is the later style circle pattern used in the 80s. The circle pattern 205 uses a seal that is mounted on the transfer case in an aluminum seal housing. The figure 8 transfer case has it seals in the adapter between the transmission and the transfer case. The figure 8 transfer case uses a lip seal in the housing and a O-ring on the shaft of the transfer case itself. Most cases when the transfer case fills up with tranny fluid from the transmission it is the o-ring that dries out and cracks or gets hard that's what happened to my suburban.
Old 01-10-2013, 05:57 PM   #6
SunSoaked
SunSoaked's Avatar
I have both. What confused me is the old style I have doesn't have the adapter, I bought it that way, so there wasn't any "seal housing" to transfer over to the newer round case which didn't come with one either.
Thanks for the info.
Old 01-11-2013, 06:04 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
bling bling ... http://www.northwestfab.com/NP205-Bi...ket_p_46.html#
Rich
1972 K5 Blazer CST Click HERE
Old 01-11-2013, 08:16 AM   #8
stanton77
These guys sell one, and it's pretty reasonable.
http://www.quad4x4.com/qu50188.html
Old 01-11-2013, 02:15 PM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
I would recommend calling AA to see what they recommend. When I did my NV4500/205 swap the kit included a sealed front bearing to install in the front of the 205 to prevent the tcase fluid and trans fluid from mixing.
You can kind of see the sealed bearing in this picture. Mine is a figure 8 tcase but I would imagine they have a sealed bearing for a round 205 as well.
Before without the sealed bearing
DirtyLarry is offline   Reply With Quote
Old 01-11-2013, 02:36 PM   #10
CrewCab59
CrewCab59's Avatar
As above you need the bearing retainer and seal. That's what holds the oil and bearing from walking around.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
Old 01-11-2013, 08:40 PM   #11
kwmech
Originally Posted by mcmlxix View Post
That is for the front output, I'm sure they could make one for the input though. They've made some custom stuff for me in the past
Old 01-11-2013, 08:41 PM   #12
kwmech
OR, you could go to the wrecking yard with a 1/4'' allen wrench and probably find multiple 203s and swipe one off of one of those.
Another thing, if you had swapped the input gear to a short input, you probably could have forgone the 'custom adapter'
Old 01-11-2013, 10:29 PM   #13
SunSoaked
SunSoaked's Avatar
Thanks everyone. Got it figured out
