01-10-2013, 07:33 PM | #1 |
Best tire size for a 3/5 drop on rallys
So im wanting some opinions, im picking up a set of 6lug rally wheels tomorrow , and im trying to figure out the best tire size to put on them that dont look too small but dont rub. Truck has a 3 in front drop and if it ever quits RAINING/SNOWING ill put the back springs on. What are some suggestions for tire sizes. And also, for those wanting babymoons on their rally wheels, ive come up with an idea, rivet the tabs/clips like the old 50s trucks used to have to hold them on. Ill experiment and see what happens. Thanks guys in advance
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
01-10-2013, 09:07 PM | #2 |
I am a Referee of life.
Re: Best tire size for a 3/5 drop on rallys
There's a seller on E-Bay that sells the clips in a bolt on design.Only problem is he claims they're only compatable with the 5 lugs.
I'm running 225-70/15 and 255-70/15 on mine with a 2 1/2-4 drop.Using Rallies.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-10-2013, 11:38 PM | #3 | |
01-11-2013, 12:10 PM | #4 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
01-11-2013, 02:01 PM | #5 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Although mine are five lug, the rally's are 15x8 with 275/15/60,s all four corners. 3-1/2" drop up front because 4-1/2" rubbed in the turns and bumps. 4" drop springs out back on a LWB 72 C-10 w/350/350tb...A 5" drop in the rear is going to require a "C-notch" in the frame, 4" is the limit. Hey paneldeland, you have a link for those clips?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 01-11-2013 at 02:07 PM. |
01-11-2013, 04:21 PM | #6 |
Just out of curiosity where did it rub? I'm trying to spec out a build and I really want to do 295/45/18s at all 4 corners which are 1/2" taller than your 275/60/15s and an just under an inch wider. I was looking to do about a 3&4 drop. The rims I'm looking at have a 6.6" backspace (1.3" offset) so being too far out will not be the problem, if anything I'll need to do a spacer. Just looking to figure out where the problem areas are. Oh, BTW it's going to be a 4 corner Porterbuilt coilover build so some tweaking would be possible at build time. Also curious if the aftermarket front tubs from Hills Rod & Custom address this problem or are they really only for dealing with heavy dragger drops?
01-11-2013, 07:26 PM | #7 |
Im gonna rivet clips from an old 40s truck or car at 1.75 a piece they will look good and hold on caps
01-11-2013, 07:30 PM | #8 |
Moderator
215 70's on the front with 7" rallies. 275 60's on the back with 8" rallies. Gives it a nice rubber rake.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
