Old 01-10-2013, 10:19 PM   #1
ol_skool_chevy
ol_skool_chevy's Avatar
700r4 Crossmember
Im getting ready to take my inline 6 banger out and add a 327 , with a 700r4 behind it.
Does anybody with a 64-66 have a 700r4 and can you tell me if this crossmember will work or does it need and drop to it?
Transmission Crossmember WITH POLYURETHANE Pad; UNIVERSAL Fit; 26" to 36" Framerail Width; NO Drop
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 01-10-2013, 11:28 PM   #2
blazins10
blazins10's Avatar
Re: 700r4 Crossmember
straight is fine , mines alot like that
///Relaxed Atmosphere
blazins10 is offline   Reply With Quote
Old 01-10-2013, 11:36 PM   #3
ol_skool_chevy
thank you...I didnt want to pull my motor and be half way into having the new one in with a wrong crossmember. that would suck.
Mark with Chalk
Cut with a torch
Old 01-11-2013, 02:14 AM   #4
blazins10
blazins10's Avatar
that would suck , i just cut all mine out slide in the combo , leveled it at the carb mounting flange and bolted it in worked great but i did have a driveline made
Old 01-11-2013, 02:43 AM   #5
Captainfab
60-66 Nut
The factory trans crossmember has the trans mount, mounting surface at 3/8" above the inside of the lower flange of the frame.
Old 01-11-2013, 09:04 AM   #6
ol_skool_chevy
Gold...thank you
Mark with Chalk
Cut with a torch
