Old 01-10-2013, 11:53 PM   #1
rs74
rs74's Avatar
How much difference between 3/4 and 1 ton frames
I am thinking about building a one ton dually 4x4. Naturally I am thinking of looking for a 3/4 ton 4x4 frame since it would be the easiest to do. I think. But on the other hand would the C30 frames be built stronger. I have a title less 84 K30 that I am going to take out the Dana and the 14 bolt rear use. The 80's model one ton frames are a couple inches taller I think over the 3/4 ton frames.
If I were to use a 3/4 ton frame would I really lose that much in hauling capacity.
rs74 is offline   Reply With Quote
Old 01-11-2013, 12:09 AM   #2
SS Tim
SS Tim's Avatar
Re: How much difference between 3/4 and 1 ton frames
The later frame is not a direct swap. Most people doing a K30 convert the existing frame. As to the frames this will probably help.
C Blazer
C10 115
C10 127 6.04" height 2.53" flange width 0.156" thick 2.98 section modulus
C20 127 6.11" height 2.46" flange width 0.194" thick 3.71 section modulus
C20/30 133 (Longhorns) 7.20" height 2.77" flange width 0.194" thick 5.05 section modulus
C30 157 8.18" height 2.97" flange width 0.224" thick 7.29 section modulus
K Blazer
K10 115 6.02" height 2.71" flange width 0.141" thick 2.70 section modulus
K10 127
K20 127 6.09" height 2.75" flange width 0.186" thick 3.48 section modulus
SS Tim is offline   Reply With Quote
Old 01-11-2013, 12:12 AM   #3
rs74
rs74's Avatar
Yeah i was just thinking of using the 67-72 frame and the 84 front and rear axle/suspensions. Just not sure which way to go towards yet. Either go with the 4x4 or convert a C30. I don't plan on using it everyday for heavy hauling but if I wanted to haul a load of rock or something I would want to make sure the 3/4 ton frame could handle it if that is the route I chose.
Old 01-11-2013, 10:52 AM   #4
gerfunken
gerfunken's Avatar
I guess a lot of it is what do you want to do on the back-end of the truck? The -30 is substantially longer than any of the K series trucks, so there's not a matching bed that you can just drop on it.
Not to say it couldn't be done... lots of guys have turned a long bed into a short bed... but I've never seen anyone lengthen a longhorn bed into a, ummm.... ultra-long-long bed? Looks like you'll need an extension....
Unless, of course, you decide to cut the frame...
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 01-11-2013, 11:02 AM   #5
rs74
rs74's Avatar
I was thinking more along the lines of a flatbed whether it is on a 3/4 ton frame or a one ton. I don't plan on using it full time. I am getting rid of my 03 2500HD 4x4 crew and I just need a good ol heavy truck to do my hauling with. I also want something different and there don't seem to be to many people that have a 4x4 dually in the years between 60-72.
