Old 01-11-2013, 12:10 AM   #1
rs74
rs74's Avatar
Was A/C an option for all years from 67-72
I have seen more 71 & 72's with A/C more than 67-70 trucks. I am a bit new to these years. In fact I am not sure that I have seen any 67 or 68's with air yet. Surely they had it though.
rs74 is offline   Reply With Quote
Old 01-11-2013, 12:46 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Was A/C an option for all years from 67-72
Yes, it was an option for all years. Not common in the '67 & '68 though. I just sold a '67 A/C dash. They are a one year only item because of the small ignition switch hole & bezel.
LockDoc
Leon
Old 01-11-2013, 01:05 AM   #3
rs74
rs74's Avatar
LockDoc
Thanks. That is what I was wondering. I am thinking of building a one ton dually 4x4 and would like to have an A/C cab. I like all the front ends on all the years but for some reason I like the 67-68 front ends on one tons better. I guess I could still do that if I end up with a 69-72 cab.
Old 01-11-2013, 01:29 AM   #4
Andy4639
Old member
Andy4639's Avatar
Talking Re: Was A/C an option for all years from 67-72
My first truck was a 67 and it had factory AC, power assit steering and over drive with a nice 283 engine. Everything worked great on that truck until the fire consumed it one morning!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-11-2013, 01:37 AM   #5
ole dollor
ole dollor's Avatar
you should be able to get a complete a/c unit that will fit your truck and look almost like a factory unit..
ole dollor is offline   Reply With Quote
