Old 01-11-2013, 12:49 AM   #1
savatreatabvr
savatreatabvr's Avatar
Hidden HORSEPOWER in Side Gapping your Spark Plugs?
I first heard of "Side Gapping" spark plugs here on this forum, it made sense to me so I tried it on a fresh set of plugs. Before I got started I read articles on SG that explain exactly how to modify the plugs in detail and also say racers have been doing this since the 60's to increase performance, well I'm quite disappointed with this SG trick because it did nothing for my performance. I wasn't expecting a major gain in horsepower or gas mileage but I expected something, anything, I just didn't see it! I hope you guys have had better results SG your spark plugs, I'm not impressed!
savatreatabvr is offline   Reply With Quote
Old 01-11-2013, 12:54 AM   #2
king-918
king-918's Avatar
Re: Hidden HORSEPOWER in Side Gapping your Spark Plugs?
Electricity will only seek out the shortest/ lowest point of resistance. That why the power3 plug don't do anything but last longer as you have 3 points to wear. point blank at most you risk a short
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 01-11-2013, 02:03 AM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
You don't have a tonight quench combustion chamber like high performance engines have.
So results will vary.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-11-2013, 02:17 AM   #4
king-918
king-918's Avatar
You shave these then did you make sure that they all point in the same direction after being installed?
<----Christopher
Oklahoma
Old 01-11-2013, 04:48 AM   #5
bk2life
indexing them will work better then SG
bk2life is offline   Reply With Quote
Old 01-11-2013, 04:59 AM   #6
cory d
cory d's Avatar
did that on a honda 1.8 with CVCC just for the hell of it. no point on doing it on that, it just ignites a small chamber behind the exhaust valve then blows through it to ingite the charge in the cylinder
cory d is offline   Reply With Quote
Old 01-11-2013, 07:54 AM   #7
Keith Seymore
Keith Seymore's Avatar
Racers are looking for performance gains measured to the thousandth of a second (.001).
Did you think you would be able to perceive that via "seat of the pants"?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-11-2013, 10:11 AM   #8
INSIDIOUS '86
K
That's about the size of your bumper vs the other car at the finish line
Old 01-11-2013, 11:15 AM   #9
kalbert
"Side Gapping", indexing, using fancy Split Fire or copy cats don't do much if anything. In high power precision applications where a couple thousandths of a second matter, it equates to a near immeasurable power increase.
I did try an E3 plug in my weed whacker, it starts easier, but I contribute that more to the plug being new. It did not cut through weeds noticeably faster. It still would not cut down a tree.
Synthetic oil falls to this as well. Superior lubricating qualities for longevity, but any power gain achieved would be insignificant.
kalbert is offline   Reply With Quote
Old 01-12-2013, 12:29 AM   #10
savatreatabvr
I've heard changing to a hotter plug doesn't do anything either except make your engine run hotter? I've seen people flip their factory air cleaner lid upside down to increase air flow which would increase performance right, also never worked for me!
Old 01-12-2013, 12:55 AM   #11
kelsfine69
18 Till I Die
kelsfine69's Avatar
That does work(flipping the air cleaner), proved it one night with a couple races, was a good couple car length difference, same night same trucks...
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 01-12-2013, 03:26 PM   #12
Redcap
I have some snake oil to sell you.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-12-2013, 05:47 PM   #13
INSIDIOUS '86
Beaver another reason to do this is also it helps deter detonation from the ground strap being to hot as well. Flipping the air cleaner base in the stock aircleaner does work. Especially so with a high flow filter. Indexing the plugs helps at higher rpm as well.
All these tricks are small on engines with a lot of power tapped out and many mods and improvements to make more power efficiently.
For you a stock 454 isn't going to see anything.
Try the big three. Intake, exhaust, cam. In that order. Don't want to tear down for a cam? Higher lift roller rockers can essential make your stock cam seem bigger. That's 10-15 hp guaranteed.
Do all these things and I will assure 75+hp gain
Old 01-13-2013, 04:38 PM   #14
kalbert
Flipping the lid or using an open element housing doesn't net much on it's own. In most cases the air filter system is engineered to meet the stock engine's airflow requirements. If you do things to other parts of the engine to allow it to use more air, then you would need to change the filtration system to accommodate.
Hot/cold plugs refer to the center electrode's ability to dissipate heat, changing to a hotter or colder plug is usually done to control preignition. Often in an older engine a hotter plug is used to keep clean and free of oil deposits that can retain heat and cause preignition. The tip being too hot itself will result in problems with preignition. Colder plugs are often used in high compression and forced induction engines where having the tip disipate heat faster reduces the possibility of preignition. Too cold and the tip won't be able to burn off deposits (which also cause preignition).
Old 01-13-2013, 08:19 PM   #15
Hevy
Hevy's Avatar
If you have a 600 cfm carb, flipping the air filter lid still leaves you with a 600 cfm carb. It can't take in more air than it's maximum.
Hevy is offline   Reply With Quote
Old 01-13-2013, 08:39 PM   #16
INSIDIOUS '86
False a Venturi fed the right way can take more than it can support but that's a whole other discussion
Old 01-14-2013, 02:15 PM   #17
Pyrotechnic
Pyrotechnic's Avatar
Depending on outside temperature, an open element air cleaner can actually be worse than the factory setup that has a tube that goes straight to the radiator support.
For example, on a 100 degree day with a 14x3 open element K&N filter, I installed a temperature probe inside the filter housing to measure the temperature of the incoming air. I did some stop and go driving the average temperature I saw was 180+ F. Not good.
Yes, the factory air cleaner is restrictive and there's no denying that, but by changing one thing you sometimes create another problem that slows you down.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-14-2013, 02:24 PM   #18
INSIDIOUS '86
Very true. This is why people use coated headers and no heat risers in the intake along with lower thermostats and true cowl inductioning. On my old 305 I took the stock air cleaner an cut the baffles and screens and removed and sealed the heat riser and cut the front off the cure support adapter to make ram air. That 305 loved it
Old 01-14-2013, 09:02 PM   #19
savatreatabvr
I'd like to see a pic of that home made Ram Air!
Old 01-14-2013, 09:36 PM   #20
INSIDIOUS '86
Well I will try and make it but basicly it's just all the stock stuff remade to work how I wanted
