01-11-2013, 01:33 AM | #1 |
best auto floor shift ?
looking to change out my old granny 4 speed to a th350 auto, been looking at lokar floor shifts and b&m. the lokar's have one that bolts to the floor and one that bolts to the trans, i am thinking of a 23" shifter....any way i also want room to move my under dash a/c to the center of the dash and not be mostly on the right side like it is now, has any on here done the auto floor shift and what shifter did you use....and will it be back further from the dash to give me more room to move my a/c to the middle. also have a bench seat at this time.
01-11-2013, 02:16 AM | #2 |
Old member
Re: best auto floor shift ?
I just redid mine and pulled the B&M shifter out. I liked it and it served me well for 18 year are so. The thing I didn't like is I could see what gear it was in at night.
I put a S-10 Shifter in it now. I had the 60-40 bench out of a 89 Chevy truck and they work fine. B&M: S-10 shifter:
01-11-2013, 12:52 PM | #3 |
Andy4639 : thats a nice looking set up you have. i might look around and see what i can find on something like you have also. the lokar is kinda high in price.
01-11-2013, 02:51 PM | #4 |
i have a Hurst Promatic. Works great. you lift up on it and pull back then push down on it and just smack it backwards to go in D or lower. It is what was in the truck when i bought it.
I want a ridiculously tall "rat fink" looking shifter. |
01-11-2013, 03:31 PM | #5 |
Why not find a 67-72 auto column? and if you cant find the frame to trans brackets you could buy the cpp linkage.http://www.classicperform.com/tech_a...geStoryweb.pdf
Stovebolt-It is painted |
01-11-2013, 03:42 PM | #6 |
Wide n'Low
My son is bent on having a floor shifter as well, and has been looking at these
http://www.americanshifter.com/catalog/Shifters I am interested in what other options we have out there.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
01-11-2013, 05:13 PM | #7 |
Not mine but think this will work for your truck?
http://dallas.craigslist.org/dal/pts/3462047857.html
01-11-2013, 05:27 PM | #8 | |
01-11-2013, 06:35 PM | #9 |
Parts and more parts
I am using B&M shifters in two different trucks, right now and they work pretty well for me. The Megashifters, do have an indicator and they work.
Frank |
01-11-2013, 08:30 PM | #10 |
Old member
My truck had the factory three speed column when I bought it and I found a factory tilt for a four speed in a junkyard truck. I swaped it out when I did the 4 speed transmission swap years ago. When I did the 700 R4 swap I bought the B&M shifter. Nothing wrong with it at all except couldn't see what gear it was in at night. My wife didn't like it so I finally swapped to the S-10 shifter now that I posted.
The S-10 shifter also add's some insurance as well. The way I have it wired even if you crank the truck up it want come out of park unless they know what to do to the shifter. That's another reason I like it.
01-11-2013, 09:39 PM | #11 |
i have thought about changing over to an auto column , and really would like that the best, my son has a lead on one but so far it has not paned out, so i have been looking at some of the floor shifts on line...and was wondering what might be the best for the lowest money. i really like what some of you had done and just getting some options on doing it. i have the trans, lines, converter ,one piece drive shaft, flex plate,cross member....all i need now is a starter, flex plate bolts, and a way to shift it..the column shift would give me more room in the middle.
that one in dallas on craiglist looks like a good one ,but thats almost 350 miles away from me. thanks everyone so far for the info. and pic's and more are welcome. not to sure which way i should go. |
01-11-2013, 10:39 PM | #12 |
Old member
The B&M and S-10 shifter's use a cable which is real easy to install. It will need the trans mount for the side of the transmission are you could make one I guess. I used the B&M one and it works fine. I need to buy a longer cable for it but as of now it's fine.
I would offer you the old B&M shifter but I have pplans for it in a golf cart I'm building.
01-11-2013, 10:53 PM | #13 |
Not sure if it has automatic but might be worth the try asking.
http://lubbock.craigslist.org/ptd/3509753772.html
01-12-2013, 01:30 AM | #14 |
B&M mega shifter
Fuzzy |
01-12-2013, 03:51 AM | #15 |
I have the Lokar 23" tall double bend shifter, bolted to the trans and i love it!
Posted via Mobile Device |
01-12-2013, 11:41 AM | #16 | |
01-12-2013, 12:03 PM | #17 |
here is mine as it is, the a/c is mounted to the right of the shifter, i would like it in the middle . center room is what i am after, and i would love to convert over to and auto.trans.
01-12-2013, 12:10 PM | #18 |
thanks Andy4639 : what year s-10 should i look for like yours, do you know if others vehicles floor shift would give me the room i need...
01-12-2013, 12:14 PM | #19 |
01-12-2013, 01:26 PM | #20 |
I have Lokar 'nostalgia' 36" double bend hooked to a 700r4. I like it . There is a taller one, but this one is great on my 'nice out' DD.
01-12-2013, 03:22 PM | #21 |
Old member
I want to say a 2000 Blazer is what I got it out of. It's got the brake solenoid wiring in it. This is the anti-theft part for the truck. The reverse light hook up I had to modify it to work but nothing major. If you get it I can help you with the wiring and the small mod for the backup lights.Nothing major it's really simple.
01-12-2013, 10:13 PM | #22 |
Andy4639 : i went and looked at a 77 c-10 today with tilt wheel, decided not to try and use it, shift indicator is in the dash and i need one on the column , i will look around and see if i can find some s-10 stuff, i still would like to have a auto column, but i am really getting anxious about doing the swap to the th350. i may have to use a stick to shift it with...lol . thanks for the info. i may be asking you on install info.
01-12-2013, 10:24 PM | #23 |
Old member
That's fine Just LMK if I can help. It wasn't that hard. The one thing you will need to do is plug up the old hole.
Here is the thread I have on it. http://67-72chevytrucks.com/vboard/s....php?p=5630912
01-13-2013, 03:21 PM | #24 |
love to see a pic of it..
my build thread -- (http://67-72chevytrucks.com/vboard/s...d.php?t=438604) |
