01-11-2013, 10:15 AM | #1 |
Project Heaven in my 67!!!
New Dash, problems...
I bought this dash new in the box from another board member.
http://67-72chevytrucks.com/vboard/s...d.php?t=427018 I finally got it installed and so far I have run into a few quirks that I am sure I am just doing something wrong. -The temp gauge isnt reading anything at all (Wondering if the sending unit isnt working or possibly the sending unit is the wrong one to make the gauge work????) -No lights in the dash, turn signals work, but no illumination lights (Maybe bad headlight switch????) Anyone got any ideas on this???? |
01-11-2013, 10:55 AM | #2 |
Active Member
Re: New Dash, problems...
First thing I would check is the circuit board contacts to make sure they're not all mangled or loose. Insure the push in connector is inserted properly and making good contact. On one occasion I had one that was no in all the way and in another the circuit board contacts were mangled up.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
01-11-2013, 11:04 AM | #3 | |
01-11-2013, 11:29 AM | #4 |
The Older Generation
You aren't switching from an idiot light cluster to gauges are you? If so, you need to change some wires around on the cluster plug. You would also need to change the temp sender in the block. LockDoc
01-11-2013, 11:31 AM | #5 |
It is in a 67 so... possibly! Do you know which wires need to be switched so that I can check to see if they are in the right location???
01-11-2013, 11:33 AM | #6 |
Active Member
You may need to start by finding the sending unit to determine what you have. Usually located on the head or in some newer engines on the t-stat housing.
Look at this pic for connections and you may need to follow the wiring. http://67-72chevytrucks.com/vboard/s...58&postcount=5
01-11-2013, 11:38 AM | #7 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=491213 If it is the wrong plug for your new cluster there is a small chance you may have fried the temp gauge. If it doesn't work when you get it all sorted that may be why. LockDoc
