Old 01-11-2013, 10:45 AM   #1
PurdueSD
PurdueSD's Avatar
Ididit column for 47-54
Ive been looking at picking up an ididit column for my truck. Ididit's application specific column for my truck says its a 1" DD. From everything ive seen it looks most people use 3/4 DD. It will be connecting to the t-bird rack that came in my scotts ifs. As im sure you know itermediate shaft space isnt exactly plentiful on these trucks with a sbc. Anybody know what the deal with the 1" vs 3/4"s is?
Ididit part # 1120651020 is the one im looking at. It is no key and floor shift.
Anything else to consider?
My Lost and Forgotten build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=442712
PurdueSD is offline   Reply With Quote
Old 01-11-2013, 11:51 AM   #2
Scottshotrods
Re: Ididit column for 47-54
On the ididit column you will need a 30 inch column.For the steering u-joints you will need a total of 3 to work with your rack from us.
1.1 inch d/d x 3/4 d/d u-joint for the column
2.3/4 x 3/4 d/d u-joint for the frame
3.3/4 x 36 x 3/4 d/d u-joint for the power rack
4.3/4 d/d shaft for the steering
5.3/4 bung for the frame to secure the hime
6.3/4 hime
7.Ididit tilt steel column
8.Column drop
9.Floor mount
I can help you out for sure on the above list of parts you will need for your truck.For the 1 inch d/d on the column this is what we have been installing in our shop for over 15 years.
For Ididit this is the only column out there that comes with a lifetime warranty.This is the only column that is made in the USA 100%.This column also has 100% gm internal parts in the column.
Justin
Scottshotrods is offline   Reply With Quote
Old 01-11-2013, 12:01 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Now there's some customer service for you. You didn't even call them and they heard your needs & responded!
Dan in Pasadena is offline   Reply With Quote
Old 01-11-2013, 12:10 PM   #4
NEWFISHER
NEWFISHER's Avatar
Awsome!
NEWFISHER is offline   Reply With Quote
Old 01-11-2013, 12:35 PM   #5
solidaxel
solidaxel's Avatar
Justin takes care of his customers!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-11-2013, 03:57 PM   #6
rollinrooster
rollinrooster's Avatar
Justin nows his stuff and has some of the best customer support!!
rollinrooster is offline   Reply With Quote
Old 01-11-2013, 06:56 PM   #7
PurdueSD
PurdueSD's Avatar
Thanks Justin, I didnt realize the 1" to 3/4" universal is how it was done. Ill shoot you an email here in a bit.
Anybody know if the stock column drop will work with this column? The billety stuff doesnt really go with what ive got in mind.
Old 01-11-2013, 06:58 PM   #8
Scottshotrods
The stock column drop will not work with the new ididit column.
We have our drop that is a tubular s.s column drop looks great take a look at it on our site
www.scottshotrods.com
Old 01-11-2013, 09:00 PM   #9
PurdueSD
PurdueSD's Avatar
What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?
Old 01-11-2013, 09:18 PM   #10
Scottshotrods
[QUOTE=PurdueSD;5811413]What is the diameter of the column where the column drop bolts up?
Are the joints you supply borgeson?[/QUOTE
Two inches dia
One more thing you can do if you want something to be more in line with what you are building.You can take some 3/4 dia 120 wall tubing and tig weld these to your column and this will act as your drop and then you will need to weld on a mounting plate.You should use 3/16 plate and this will mount to your dash or the mount you will make to secure the column.
Just a idea
Justin
Old 01-11-2013, 09:19 PM   #11
Scottshotrods
The u-joints we sell
1.Uni-steer
2.Borgeanson
