Registered Cruiser
Shift Linkage help...
Trying to find a solution for the shift linkage/cable for my set up...
PB DM, with a 5.3/4l60e combo - 77SWB. What are you guys typically running? It seems the lokar shift linkage kit won't clear the firewall due to the motor being raised, and the lokar cable kit is just an odd fit causing one of the brackets to hit the brake booster Do I need to make my own linkage?
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Re: Shift Linkage help...
Question, why can you not use the stock location and linkage and not a cable
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
Registered Cruiser
The stock location should work, and possibly the stock cable, but I don't have the stock cable. It was trashed when I bought the truck.
The cable I have is from Lokar, and it would work, but the brackets they use cause interference with my brake booster (Smaller brake booster). And the cable comes up by the driver's tire, where my tubs will be going. I'm just not satisfied with the look of it... I found the lokar linkage (rod), not cable, and will try that out when it gets here. Sounds like that is what some guys are using.
Has more rust than truck...
I'm using the lokar linkage, works fine for me.
Posted via Mobile Device |
Is the linkage a solid rod or cable?
Registered Cruiser
It's a solid rod, stainless steel.
Yep, I think the part number is aca-1800
me too...had to bend it a little but works awesome...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
TruckincrazY
Ditto
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
Registered Cruiser
Yep, installed it yesterday, works perfect. Great piece imo! Thanks for the help Moose!!
no prob man...
True Addiction
Could you upload a picture? Thanks,
RCC |
#13 |
Registered Cruiser
Hope this helps... Pretty straight forward install.
#14 |
True Addiction
I was hoping this would work from me but it appears it is unlikely a rod is going to work; just not enough room. Has anyone tried the Lokar column cable shift linkage? I wasn't 100% sure if the brackets would work on the steering column.
Thanks,
RCC |
#15 |
meowMEOWmeowMEOW
This is where floor shifters make life easy.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
