Old 01-11-2013, 06:23 PM   #1
dan468
dan468's Avatar
1972 can mount height difference
The cab mounts are different sizes. Where do the taller ones go, front or rear?
68 C-10
Build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=414699
dan468 is offline   Reply With Quote
Old 01-11-2013, 06:42 PM   #2
chiefcfd
chiefcfd's Avatar
Re: 1972 can mount height difference
If I remember correctly the short ones go in front. Taller ones in rear.
chiefcfd is offline   Reply With Quote
Old 01-12-2013, 04:26 PM   #3
TexC-10
TexC-10's Avatar
Do you have a picture of the mounts? Mine had out of 8 pieces, 4 the same height and then 2 sets of 2 with slight different height. I assumed the ones (4) with the metal in them slipped down and rested in the hole on the frame. I'll have to check mine when I get home.
1972 C/10 mutt.
TexC-10 is offline   Reply With Quote
Old 01-12-2013, 04:29 PM   #4
dan468
dan468's Avatar
Sorry, no pics right now
68 C-10
Build thread
Old 01-12-2013, 04:34 PM   #5
Lee H
Lee H's Avatar
Courtesy of LMC, looks like the thinner ones go up front.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 01-12-2013, 04:34 PM   #6
dan468
dan468's Avatar
Perfect!!! Thanks
68 C-10
Build thread
Old 01-12-2013, 05:09 PM   #7
YBNORML
YBNORML's Avatar
As much as I can't stand LMC, their catalogues sure are useful. And sometimes easier to decipher than the Factory Assembly Manual.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
