connector C100 and C153 pin labeled "Ignition 3 Voltage??
does anybody know what this circuit does?
my harness is from a 2001 GMC 5.3 and it has brown wires called "ignition 3 voltage" according to wiring charts, one was in C100 pin n and other C153 pin c. traced wires out and it ends up on a small black 2 pin connector that i dont remember being hooked up. the other wire off the 2 pin connector seems to hook to a common ground splice. can i just delete this whole circuit?
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
