![]() Join Date: May 2011
Another power steering question
Swapping in Power Steering Here soon. Do I need to change the Idler Arm as well as the pitman arm? Doing some searches I hear both ways.
In a 69 btw. |
Re: Another power steering question
That is a very good question you have risen I have no answer , at fisrt thought I would say no but then after thinking about it it is a definte maybe. So when I get back to my shop I am gonna measure both to see the answer for myself. I will look for this post went I get back wiith the numbers and post the answer so that it can help anyone needing the sameinformation later in their build. Jim
I am a Referee of life.
I didn't and it seems to be fine.I know the alignment is good and that didn't change from before to after.I used the 68 pitman arm since I had 68 suspension.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
![]() Join Date: Oct 2009
I didn't.
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
Active Member
![]() Join Date: Jul 2007
My memory is fuzzy but it seems that there was one that I had to change. IIIRC there was diffence in length. Best thing to do is to get a pitman arm puller and remove both and compare.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
The LMC catalog has the Idler Arm listed for 67-72. Now the Pitman Arm is listed 67-68, 69-72, and Pitman Arm-W/PS 67-72 so there are different part #'s for the Pitman Arm.
LMC catalog http://www.lmctruck.com/icatalog/cb/t.aspx?Page=128
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers Last edited by nds1968; 01-12-2013 at 11:12 AM. |
To clarify my response. I had to change the pitman arm, but not the idler arm.
Thanks Guys!
