01-12-2013, 03:09 AM | #1 |
how to REset odometer to zero?
How does a person go about resetting an odometer back to zero?
01-12-2013, 03:53 AM | #2 |
Re: how to REset odometer to zero?
its a pain in the butt. you take it all apart and after about 2 hrs of messing around with it, you'll finally figure it out.
it like a rubics cube. if you have a gauge repair place in your town, you might drop it off and 45 bucks later pick it up.. |
01-12-2013, 04:34 AM | #3 |
I can roll it back for you for nothin just pay for shipping back and forth... PM ME
68 C10 Stepper #1- GONE 68 C10 Stepper #2 1977 Chevy Cheyenne...gone...was my first Chevy 04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD 99 Sierra Stepside, 17 Denali HD, 84 K10 My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333 My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310 |
01-12-2013, 08:30 AM | #4 |
Question If you were to hook a drill up to the end of speedo cable and run backwards would that roll it back,or is it just designed to go one way.....
1964 BBC 402 4x4 |
01-12-2013, 08:54 AM | #5 |
beuller?
01-12-2013, 11:26 AM | #6 |
01-12-2013, 11:28 AM | #7 |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
01-12-2013, 12:03 PM | #8 |
You could always find a truck for sale with 25,000 original miles and ask the guy how he rolled the odometer back
I think the PO for my truck changed out the rear end, because hte speedo is way off (4.11 to 4.57 is my guess), and therefore the miles on the odometer aren't right either (higher than they should be). Dialing back the odometer is an interesting thought just to get mine accurate, but I dont' know how many miles were on it whan the rear was changed, so I guess that accuracy is probably not really possible.
Nick Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986 http://67-72chevytrucks.com/vboard/s...d.php?t=545356 Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck. |
01-12-2013, 12:06 PM | #9 |
01-12-2013, 12:46 PM | #10 |
Project Junkie! Fishing Poor!!
Why does everyone want to go backward with the odometer? Just roll it forward to 0 again. You don't have to take a chance of breaking it by taking it apart that way. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
01-12-2013, 01:16 PM | #11 | |
The Older Generation
The thin plastic piece that is discussed in this thread is made out of a brittle material on purpose. It is almost impossible to disassemble the speedometer without breaking it. When I re-set mine to 0 miles in the Suburban (new crate motor) I also broke the plastic piece. I used a piece of a plastic container that a slip on seat cover came in. It was the correct thickness and was not brittle. I cut it oversize and put the broken pieces together laying on top of the new plastic. I then misted very a light coat of Grey, sandable automotive primer over the top of it. You have to have the paint can far enough away that it doesn't blow the pieces away but it made a perfect outline of the piece on the new plastic & made it easy to cut out. LockDoc
01-12-2013, 01:31 PM | #12 |
I just have to ask..what's the purpose in rolling back the odometer? On the surface it seems a little dishonest. I know there must be a good reason. Adding a new motor doesn't account for the wear on the rest of the truck.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
01-12-2013, 02:14 PM | #13 | |
Moral of this story is It really doesn't make any difference what the speedometer says, you better know what you are looking at when you buy a supposedly low mileage 45 year old truck. LockDoc
01-12-2013, 02:16 PM | #14 |
Moderator
I don't believe any odometer that is 40 years old, much less any stories of original mileage. The truck's condition will speak for itself.
01-12-2013, 02:32 PM | #15 |
Too many projects
I personally believe an odometer that's 70-90k easier than one that is in the 10 to 40k range, as it almost certainly rolled over at one point. Also, most states exempt odometer mileage on the title for these older trucks.
All of my current vehicles started over at zero, as they received aftermarket gauge clusters when I redid the interior of each. Heck, the 68 K20 still says 2 miles as I haven't finished wiring it up a year after I installed the new drivetrain. Easiest way is to roll it forward to zero or just take note of what the mileage is/was whenever a major update is performed.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
01-12-2013, 02:37 PM | #16 |
Mine has rolled over twice that I know of. It shoes 75K on the clock but condition shows it's older.
It's kinda like dating a chick that has had work done. Unless it's maintained it doesn't last long. Posted via Mobile Device
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-12-2013, 02:39 PM | #17 |
I agree with the last four posts which takes me back to my original question. Why change it all? With that said, my frame off restomod Has a new Autometer speedo. I went thru the whole truck so it helps to track overall wear.
01-12-2013, 02:54 PM | #18 | |
I set mine at zero just to make it easier for me to keep track of the mileage on the new crate motor. That way I don't have to try and keep track of a piece of paper that I wrote the mileage down on and stuck in the glove box, all I have to do is look at the odometer. It's just a convenience thing for me and I see nothing wrong with it... My '70 Chevy pickup just turned over 100,000 miles and shows 384 miles on the odometer. Even though it is a really nice original truck, anyone that knows anything about these trucks at all would know different. Just my 2¢ worth. LockDoc
01-12-2013, 02:56 PM | #19 |
First step: Check your states laws governing odometer manipulation.
Second step: Decide it is not worth it. I believe that Indiana state law states that if you change odometer that you must affix a metal plate that states the actual mileage when changed.
......its not what your askin', its what your gettin'.... .......every time I screw up, I learn something. Needless to say, I'm learning all the time............ |
01-12-2013, 03:15 PM | #20 |
I do kinda wish these trucks had an odometer to read over 100k mine says 22k and i know its at least 120k but looking at the truck when i bought it id say it has more but the way it drives and all the steering parts suspension etc look 40 years old to me so idk it might only have 120k i guess ill never know my title said it had 96k when the po bought it he said he hardly drove it and i got it with 12k and my title now says exceeds mechanical limits which means over 100k
Posted via Mobile Device |
01-12-2013, 03:45 PM | #21 |
I fall on the side of the fence where all that matters is condition - be proud of your miles! Since nobody trusts original mileage claims anyway, especially when they are false, it's really not worth it. Plus, I don't want to break the odometer by trying to roll it back/forward, because if anyone would, I would. I will continue to roll my odometers forward the old fashioned way, with the tires (if I can ever get it off jack stands, that is...) Having said all that, I can understand why some folks want to roll em to zero after a total resto or a new engine install, etc. All personal preference, but for me, I like it when it's HIGH mileage (except when I'm buying one, of course..)
01-12-2013, 03:57 PM | #22 |
Sounds like hot topic !!!!!
01-12-2013, 04:15 PM | #23 |
i always found it was quite easy and alot of fun to just put it in drive on a daily basis and it got to rollover to zero in short order then the stupid manufactureers went to the million mile odometers it was not that easy
01-12-2013, 04:50 PM | #24 |
It can be, but we are kind of hijacking the OP's thread. The original question was only HOW to do it, not the pros & cons.
Sorry OP., I'm done... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-12-2013 at 04:57 PM. |
01-12-2013, 05:01 PM | #25 |
Old member
I have a couple of them done. I keep them for spares.Just in case. Now I have the speed hut speedo I don't need them. Huh...
I agree with LockDoc if it's my truck who cares.
