06-09-2003, 08:19 PM | #1 |
71' Carrier Bearing removal (???)
I just go out from under my 71' lwb Half ton, 2WD, The carrier bearing dose not look to be removable on this truck. (Major ?)
I do see some rivets that hold a bracket to the trailing arm cross member. Are these to be removed for removing the drive shaft? or is there another place to look? I do not see another place for bolts to be holding this thing together. If the rivets are to be removed, I have to start wondering about the rest of the truck (Original Equipment or newer?) Thanks for hte help, Ed |
06-09-2003, 08:29 PM | #2 |
carrier bearing removal
there are two bolts on top of the bracket that go through the bracket and into the bearing assembly. i think it's about a 9/16 head bolt. i've replaced two of these things.
68 SWB Stepside 72 Cheyenne 20 72 SWB Fleetside 72 Suburban 72 2wd Blazer |
06-09-2003, 10:31 PM | #3 |
there are two bolts on top of the mid shaft bushing. they are 9/16. you will have to remove the drive shaft. Once you have the drive shaft out you will have to remove the bolt ( I think it is a 3/4)from inbetween the universal joints. You might have to beat the old bearing off the shaft. Then install the new one.
Demon
69-C10 LWB 71- fleetside shortbed It's a shame stupidity isn't painful Never play leapfrog with a unicorn |
06-09-2003, 10:46 PM | #4 |
Nothing fits but the oil
Try not to beat the old bearing off, or beat the new one on. Take it to the shop and have it pressed off, and pressed on. The 2 bolts are located on top of the carrier holder, between the bottom of the bed and the center support.
Land of the free Because of the brave |
06-09-2003, 11:01 PM | #5 |
To get the old bearing off after splitting the shafts remove the rubber surround and then attach a puller. Tension the puller and then heat the bearing with a popane torch. It'll pop off. I find the new ones just slide back on for me.
Saskatoon, Saskatchewan Canada |
06-09-2003, 11:21 PM | #6 |
Actually if you want to get technical about. If you heat the new bearing to 100 degrees F the bearing should slide on the shaft with no problem. For you enginering guys it should be a small k6 fit.
Demon
06-10-2003, 03:52 PM | #7 |
Thank ypu all for the information. I would have been out there all Saturday removing those rivets. Then I would have to have kicked myself. It took all of 10 min. Thanks Again, Ed
06-10-2003, 04:41 PM | #8 |
Spank 'em if you got 'em!
Hey kspops, I got a press I've been itchin' to use if your coming up this way!
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
06-10-2003, 04:42 PM | #9 |
By the way, welcome to the board!
