Old 01-12-2013, 06:09 AM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up robnolimit Article in Street trucks
Man I found this searching the net and reading my copy of Street Trucks mag.
http://www.streettrucksmag.com/tuned-to-perfection/
I want to know about moving the rear coils to the out side of the frame. I like this and think it would make a nice addition to the relocator I bought last summer.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-12-2013, 11:38 AM   #2
Dano69c10
Dano69c10's Avatar
Re: robnolimit Article in Street trucks
I could be wrong;
I think that is not a stock rear frame. With a stock frame, your springs can't be moved outside.
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 01-12-2013, 03:17 PM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: robnolimit Article in Street trucks
Originally Posted by Dano69c10 View Post
I could be wrong;
That's what I was thinking also. I just never saw any mention of it being a modified frame are either I missed it. Was just wanting to know for sure. Thanks.
Old 01-12-2013, 06:48 PM   #4
duallyjams
duallyjams's Avatar
That's a frame rail kit the Rob offers also.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 01-12-2013, 08:34 PM   #5
Nsanehotrodz
Nsanehotrodz's Avatar
Rob for President!
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 01-12-2013, 09:06 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: robnolimit Article in Street trucks
I read the other articles on the website and it talked about the frame being a custom built frame so I guess I want be getting that mod for the 71.
Here is where I was reading about it.
Old 01-12-2013, 09:25 PM   #7
65Gregg
65Gregg's Avatar
If I'm not mistaken the frame is a back half conversion used to convert a long bed to a short bed.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline   Reply With Quote
Old 01-12-2013, 09:26 PM   #8
andrewmp6
Rob is working on a rear frame back half kit.Take a look at http://67-72chevytrucks.com/vboard/s...=507066&page=4
andrewmp6 is offline   Reply With Quote
Old 01-12-2013, 10:10 PM   #9
CSGAS
optomistic ah-so
CSGAS's Avatar
It's true that Hellboy has a custom constructed chassis, modeled after the semi-monocouque approach used in high-end exotic sports cars.
However, the article about relocating shocks and springs is not based on Hellboy.
It's based on the rear chassis kit Rob offers. That kit is intended to help customers shorten a longbed into a shortbed, but can also be used on shortbeds as an alternative to the typical c-notch.
The panhard kit and shock relocator kit works on stock truck chassis. From what I can see, as long as the shocks have been relocated first, the spring relocators can also be installed on an otherwise stock truck.
If Rob stops in I'm sure he'll give more details. If not, I got most of my info from reading his "Make it Handle" thread. It's a long one, but very informative.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 01-16-2013, 06:23 PM   #10
aggie91
I'm just glad to be here!
aggie91's Avatar
The spring relocators will not work on a STOCK frame rail. The frame rails widen as they go over the axle.
The rails in that article and the ones Rob developed to convert a long bed to a short bed. It says that in the article near the end. It should ahve been the first thing they wrote about....
The rail kit that Rob designed is parallel from the back of the cab to the rear bumper. That is why the spring mounts ARE REQUIRED for his frame rail kit.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-17-2013, 01:10 PM   #11
robnolimit
robnolimit's Avatar
Wow, I haven't even seen the article yet. Yes, that is our new rear rail conversion kit, not stock rails. Our rai kit keeps the rails at 34 1/2" wide O.D. all the way back, so the upper spring mounts are outboard just a bit, but the spring spacing is the same as stock. The rail kit does two things. It can be used to convert a long bed to a short bed, and it raises the rail 4" over stock. Whether it is used on a long to short conversion, or to drop, or save a short bed, the bed floor MUST be raised 4". You will see a complete article in an upcoming StreetTrucks on this. We are working with a sheet metal shop to offer a 6 pc. kit to help raise the floor. Also, I will be posting up some picts of this on our BCC build.
While HellBoy doesn't have any of our production based parts on it, it's build style makes it very easy to change and test suspension ideas, concepts and parts. Last season we tested four different shock valving set ups, more spring and sway bar sets than I could count, and three different rear suspension link assemblies. All of this information goes into the production suspensions.
There is also an article coming up featuring Porterbuilts "forward lower" A-arms for C10's. We put a set of lowers on the JT and gave it to Marcel to drive to Scottsdale. He drove it outfrom LA, 300mi., went to Dino's party, Autocrossed it all weekend, then drove it home. He'll be writing about the install, the drive and all of it. - yes, we like the arms. Good job Nate.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
