Old 01-12-2013, 11:30 AM   #1
glljr
Supercharger
Having an issue on my weiand 177 I put it on the dyno yesterday to do some tuning and the vaccum secondaries are not opening at all. Put a lighter spring in checked for vaccum and couldn't find anything that would cause it. Any ideas as to what would be causing this?
glljr is offline   Reply With Quote
Old 01-14-2013, 09:33 AM   #2
68Stepbed
68Stepbed's Avatar
Re: Supercharger
Is your carb setup for a supercharged application? The carb could be getting false readings or the check ball could be stuck. Personally, I switched to a mechanical secondary carb and am very pleased!!
Exactly what carb do you have?
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 01-14-2013, 11:27 AM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
Re: Supercharger
vacuum secondary's won't work under boost. They need vacuum.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 01-14-2013, 12:17 PM   #4
glljr
Re: Supercharger
I just switched over to a 650 dp with mechanical secondaries seems alot more responsive than the 750 was hopefully get it tuned this friday, It did make 200 hp and 300 tq at the wheels at only 2500 rpm with only the primarys opening
Old 01-14-2013, 02:14 PM   #5
68Stepbed
68Stepbed's Avatar
Re: Supercharger
Boost, the only replacement for displacement.
Can't wait to hear the numbers with the new carb.
Matt
Old 01-14-2013, 05:18 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Supercharger
You HAVE to use a carb set up for a supercharger... or it just won't work right.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 02-02-2013, 11:04 AM   #7
glljr
Re: Supercharger
Tuning is done, only put down 300 rwhp and 360 ftlbs. thinking on a cam swap and going to long tubes. Any input on a good cam for the 327 its making 6 pounds of boost.
