![]() Join Date: Mar 2002
front axle dana tear down...which parts are keepers or trash?
tore down my d44 front axle knuckles, spindles, calipers, etc.
typical farm truck/rust bucket condition...needing a complete go over. what parts should i keep to sandblast and paint because replacements are rare or expensive or not available new? what parts should i buy new because it will be fast and easy? knucke spindle caliper mounting plate/dust shield (what is this part called?) calipers hub body manual locking hub internal parts ![]() |
Re: front axle dana tear down...which parts are keepers or trash?
Personally see no reason to buy parts if yours are serviceable. Save the money. Clean it up, lube and re-assemble. Obviously bearings and ball-joints are replacement items and so is the rotor if it's whacked and it is certainly easier to buy calipers than re-do them. But spindles and knuckles would be keepers.
#3 | |
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
i plan to reuse as much as possible and practical.
just in case...if beyond reusing due to rust or whatever: knuckle spindle caliper mounting plate/dust shield (what is this called?) Can these three parts be bought new? This would be nice to know before i go to speak with my sandblaster guy. i didn't see them listed at the normal vendors. tom |
![]() Join Date: Dec 2012
Personally, I would keep everything
1971 GMC Sierra 1959 GMC 100 |
I don't think you can get the backing plate,but be careful sandblasting it because it might destroy it. The caliper and bearings are still available and are the only thing I would change. Chris
Posted via Mobile Device |
