![]() Join Date: Oct 2012
With Wide tubs, What size tire?
I was looking at my truck,,,so easy to widen and fit wider tires, should be able to fit 12" wide rims...
How wide you guys running, Pictures?
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
My Carbon Footprint
Re: With Wide tubs, What size tire?
My fenderwells are just mocked-up, though they've been that way for about 4 years. Try 14" wide wheels and 18.5 (section width) tires!
My Carbon Footprint
The 3rd pic is the 15.5's on 12" wheels on the truck until I realized I could 14s with the 18.5 tires.
I'm guessing you're a coil rear end? Truck looks like great possibilities. Last edited by prostreetC-10; 01-13-2013 at 01:43 AM. |
Now yur talkin' Mr. Orygun!!
Go big or Go home!! |
My Carbon Footprint
I will say this though.....try to bypass the bias ply step and go straight to the radials like the S/R or Hoosier. I can't wait to get these off this spring. They really walk on you. Not a real big deal at low speed but when you really stuff it, it's a little scary. It's like going sideways in a school bus!
#6 | |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 01-13-2013 at 10:50 AM. |
motor exploder
I cut down a set of fleetside tubs (sectioned 4") and used them on my stepper. I'm running 18x12's with a 335/30 tire.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! |
Man of Mini-Talents
That's really cool!
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
motor exploder
Thanks Zoomin. Here's a pic of it (kinda) together. Pic is a little distorted, but you get the idea. I still have plenty of room for a wider tire, but I'm set on the 18x12 / 335 combo for now.
My Carbon Footprint
Let's get some side pics of your truck!
motor exploder
NOOOO!!!! It's even uglier from the side
![]() Join Date: Jun 2012
What are you running for a back space on those 14s and how much wiggle room do you have left.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker ![]() |
#13 |
My Carbon Footprint
Surprisingly I do have a little room. Maybe a 1/2-3/4 inch on the inside and that is based on adjusting to taste on the outside. Seems like I'm 8.5 to the inside and 6.5 to the outside (since a 14" wide wheel is really 15" lip to lip). There is certainly more room under there but the highs and lows of the bed really force you to stop where I did so the fenderwell would sit flush and look factory. Toughest part is tapering the ends so it looks factory.
#14 |
any more.....i need more pictures im going wider...
#15 |
![]() Join Date: Feb 2004
I reasearched this alot before i did it. 1st off you need to know that a 67-68 rear is1.5" narrower than a 70 up so if you want to stuff get the earlier rear un less you want to pay big for wheels. Yes you can fit a 14 wide wheel with a 9.5 bs but again it has to be made. Your cheapest option is a 12 wide with a 7.5 bs wich are readly avalible and can even be found used. The max tire you can run on them is a mikey thompson 18.5 on the early rear. I run a 12 wide with a 6.5 bs and 345/55/15 and i did not have much clearance so i made some. But you also have to consider i have about 9 1/2 " of drop on my rear so a person with stock hight should be fine with that set up. If you have the later rear i would not go less than a 7.5 bs with a 12 wide. Sorry my pics dont upload with my phone but you can see a side shot in my aviator. The tires are about 14.8 wide section width however you cant get them any more but m/h racing makes a drag radial that is a 375 but its about the same section width.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#16 | |
#17 |
Boss Hog 69 that is mean looking
#18 | |
![]() Join Date: Sep 2012
#19 |
I got pictures coming soon....29/15/15 mickey t. tires
