Old 06-09-2003, 09:52 PM   #1
bigblock73
yeller
bigblock73's Avatar
Look what I found in the woody (Blazer)...
Well when I bought the '77 it had a Kenwood deck and pair of some crappy surface mounted speakers sitting loose on the rear of the floor. The speakers were in pretty bad shape and sounded worse...so I pitched them (I am going to buy new ones), but while I was "cleaning" I noticed there were four speaker wires and two of them were coming from the side panel behind the tire (a different location from the other two). My curiosity got the best of me so i pulled the panel and look what I found...
before...
after...
closeup...
I think this is pretty cool because I never knew it was there and the PO never told me about it. I might be spending more on "speakers" than I thought
Does anyone have any info on this amp? Is it a decent amp?
Just thought you guys and girls would like to see this.
...Jeff
bigblock73 is offline   Reply With Quote
Old 06-09-2003, 09:56 PM   #2
68 Stepside
huh?
68 Stepside's Avatar
Want the manual for it, in .pdf (adobe acrobat) form. I can email it to you, just PM me.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 06-09-2003, 10:15 PM   #3
Russell
Professional Grade
Russell's Avatar
Here is the manual for your amp.
ftp://docs.kenwoodusa.com/manuals/OM...-1993-KUSA.pdf
It is either a 45x4 watt amp or an 80x4 watt amp, I've had conflicting reports, but the bulk state that it is 45x4 watt. This would make some awesome 6x9 sound or subwoofer sound with the equalizer...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-09-2003, 10:24 PM   #4
78SilveradoSWB
78SilveradoSWB's Avatar
Thumbs up
That's a nice find Jeff. Wonder though if the amp is getting enough cooling being restricted there behind the panel. Those heatsinks got to be cooking back there.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 06-09-2003, 10:45 PM   #5
bigblock73
yeller
bigblock73's Avatar
Thanks guys for the replies...TJ...I PM'd you.
ZiDigi...I can't get the link to work.
I think I will move it out from behind there and either mount it under the seat or save it for Yeller.
...Jeff
Old 06-10-2003, 12:18 AM   #6
Russell
Professional Grade
Russell's Avatar
bigblock73 - Just gotta right click and choose save as, you might need the Adobe Acrobat software, it can be downloaded off of Adobe's website for free.
Old 06-10-2003, 12:22 AM   #7
bigblock73
yeller
bigblock73's Avatar
aaahhhhh, got it...thanks! It says 80x4 or 160x2...kewl.
...Jeff
Old 06-10-2003, 02:21 AM   #8
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
nice find. was/is it hooked up to those speakers? what kind of deck was it running off?
mike
mike reeh is offline   Reply With Quote
Old 06-10-2003, 04:46 AM   #9
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Hell of a find Jeff. nice place to hide it as well but I also wonder about the heat factor there.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 06-10-2003, 08:26 AM   #10
BigRed
Happy Birthday to you! If you could rig up an in and out fan in that panel, that would work great for keeping it cool.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 06-10-2003, 08:45 AM   #11
Prerunner1982
Prerunner1982's Avatar
could put small computer fans like mike did in his console in there.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 06-10-2003, 12:20 PM   #12
bigblock73
yeller
bigblock73's Avatar
mike
The two crappy speakers were running off the deck...which is a Kenwood two-post deck (I am sure it is pretty cheesey). I am sure there were subs in back at one time running off the amp.
...Jeff
Old 06-12-2003, 11:01 AM   #13
gldevall
gldevall's Avatar
Cha ching...nice find.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 06-13-2003, 12:22 AM   #14
phantom dually
Project92 SWB stepside
phantom dually's Avatar
The rating on the amp is probabaly not the rms rating. That is likely the max output. Go with some 6x9s and a set of speakers up front. You can run it bridged at 2ohm stereo and get a little more power out of it. Likely the 2 post radio only has one set of preouts if any at all therfore it would be useless to run it in 4 channel mode as you would not have a fade option any way. If you decide to add a diffrent head unit get one with front and rear pre outs and run 2 rca cables that way you can run the amp in 4 ch mode and control front to rear fade. I would not run a set of subs from this amp as I beleive that you would NOT be happy with the results.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
