01-13-2013, 07:10 PM | #1 |
Vacuum port on intake manifold
I managed to break a port off my intake manifold vacuum fitting.
I have an 86 truck with an automatic transmission. The fitting has a port for the main vacuum line and a port on the top for the automatic transmission, and another port that was unused. I have tried to find this part everywhere and the best I can find is a corvette site that shows a similar part for around $25 before shipping. Does anyone know where I can find this part? TIA Jason |
01-13-2013, 08:18 PM | #2 |
Re: Vacuum port on intake manifold
Go to the hardware store and get a pipe to hose barb adapter.
Specifically, a brass 3/8" male NPT to 1/4" hose barb. The 3/8 NPT screws into the manifold and the end of the modulator tubing fits into the ID of the hose barb. Use a short section of rubber hose to connect the OD of the hose barb to the ridge on the actuating line. |
01-13-2013, 08:37 PM | #3 |
go to the help section of any autozone or auto parts store, they sell them in many configurations of ports and threads
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
01-13-2013, 08:52 PM | #4 |
Are you looking for a ported vacuum switch?
OReilly's or Advance should have them. If you can find anyone at those places that knows $hit from Shinola |
01-13-2013, 09:33 PM | #5 |
No..not the vacuum switch.
This part is on the back half of the intake between the carb and the distributor. It has a line that runs to the transmission and another to the main vacuum hose. I am likely to go to Lowes and use brass fittings to build a new one that will work. |
01-14-2013, 05:43 AM | #6 |
01-14-2013, 07:57 AM | #7 |
That is the piece...except mine has a 1/4" or so port on the side that goes to the main vacuum line and another 1/8" port that I had plugged off.
I broke the small port off trying to get it out of the intake. It looks like it is aluminum and mine was already somewhat malformed and bent so I decided to replace it instead of trying to fix it. I didn't know they may not be a common part. |
01-14-2013, 08:01 AM | #8 |
http://www.ecklerscorvette.com/corve...Product_Viewed
This is the closest replacement part to the original I can find. The price of these parts is a little high. |
01-14-2013, 10:52 AM | #9 | |
http://www.grainger.com/Grainger/Hos...FN2?Pid=search That's what you need.
1977 GMC Sierra Grande |
01-14-2013, 11:03 AM | #10 |
Try a pick and pull... Fittings here from one would be $3.00. Probably cost you more in gas to drive there but most all Carb'd/Auto Trans chevy's will have the one you need.
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles 1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles If it ain't broke, there is still probably room for improvement. Speed costs money, how fast do you want to go? |
01-14-2013, 12:38 PM | #11 |
