Old 01-13-2013, 09:00 PM   #1
Formanbob
bowling alley wood bed
So think of doing the wood bed out of bowling alley wood, I could cut a rabid on the underside to take car of the thickness and seal up all the edged. Anyone see a reason not to?
Formanbob is offline   Reply With Quote
Old 01-13-2013, 09:09 PM   #2
m455sx
m455sx's Avatar
Re: bowling alley wood bed
Sounds awesome!, What kind of wood is a bowling alley made of?
1970 442 convertible
1970 Cutlass SX
1962 Chevy Stepside
2011 GMC 3500HD Crewcab SLT DRW
m455sx is offline   Reply With Quote
Old 01-13-2013, 09:10 PM   #3
Formanbob
Heart pine
Old 01-13-2013, 09:13 PM   #4
m455sx
m455sx's Avatar
Heart pine is very expensive here in VA. It is very pretty. I have yellow pine in mine which is very close. Please post pictures once you get it done.
1970 Cutlass SX
1962 Chevy Stepside
Old 01-13-2013, 09:27 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I don’t know anything about the properties of heart pine, but I would suggest consulting a wood specialist prior to starting. My concern is about potential shrinkage and swelling. My uncle once built a deck out of teak from the floor of a railroad car. It was up against the house on one end and rested on a retaining wall on the far end. I know he sanded and sealed it, but I don’t know with what or if he covered all the edges and the bottom.
The first week it rained, the wood swelled (lengthwise) so much it broke through the stucco on the house and knocked over the retaining wall on the other end. It would be nice to have an expert confirm this won’t be an issue.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 01-13-2013, 09:32 PM   #6
Formanbob
Yep, this Is why I ask, I know it Is stable indoors, just wanted to start asking here first.
Old 01-13-2013, 10:13 PM   #7
Sharps40
Bowling alleys are made from maple. Often called rock maple cause its darn hard and light. Pine, including heart is about as soft as tissue paper where a bowling ball is concerned. Alley maple, if the right dimensions for milling and getting the old finish off for refinish to an exterior grade clear would be the berries for a bed.
Sharps40 is offline   Reply With Quote
Old 01-13-2013, 10:23 PM   #8
71swb4x4
71swb4x4's Avatar
I believe that both of you are correct. Generally (certainly not 100% of the time) the beginning of the lane is maple and the back (2/3rds or so) is pine.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-13-2013, 10:24 PM   #9
padresag
for starters it is kind of overkill on the thickness. you only need 7/8". secondly it is all laminated strips and the glue used would more than likely start to delaminate. only suitable for interior applications.
more than likely the reason for wanting to use it, is that you more than likely sre getting it for nothing
ron
padresag is offline   Reply With Quote
Old 01-13-2013, 11:34 PM   #10
McCoyAZ
McCoyAZ's Avatar
Being a fairly good bowler myself and knowing enough to be dangerous .........
The alley wood is very susceptable to humidity change. I'm afraid it would not be a good choice for being outside in the weather.
But it does make one hell of a workbench top.
McCoyAZ is offline   Reply With Quote
Old 01-13-2013, 11:40 PM   #11
padresag
or a countertop
ron
Old 01-13-2013, 11:53 PM   #12
ky-donzi
I do a little wood working, a really good compormise would be catalpa. It is very stable out doors, and very pretty, just kinda soft.
ky-donzi is offline   Reply With Quote
Old 01-13-2013, 11:55 PM   #13
ky-donzi
http://www.google.com/search?hl=en&c...bL6xumSXxBt8iM
Old 01-14-2013, 02:30 AM   #14
scrapmetalart
Junior Member
yep i bought 1 lane a few years ago. right past the arrows it is pine.
Its way heavy as its 2" thick!!!
frontstreetcycle on Instagram
scrapmetalart is offline   Reply With Quote
Old 01-25-2013, 09:23 AM   #15
skysoldier173rd
skysoldier173rd's Avatar
I've got a slab of that recycled into a chopping block. Dude, a piece big enough to do the bed of a truck would weight close to 1000 lbs i'm thinking, unless there are lighter versions. Great tough and durable though.
skysoldier173rd is offline   Reply With Quote
Old 01-25-2013, 03:41 PM   #16
Formanbob
This has been the one thing I am afraid of. I would be nice in the snow though. HAHA
Old 01-25-2013, 04:11 PM   #17
padresag
4' x 8' x 3" would be about 8 cu.ft. at about 47lb per cu. ft.= about 375 lbs
ron
Old 01-25-2013, 07:24 PM   #18
creep
Registered Loser
creep's Avatar
check out c10mang's build. He made a bed cover that looked like bowling alley wood. Not sure what kind of wood exactly though.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
