Old 01-13-2013, 09:14 PM   #1
clay68c10
clay68c10's Avatar
04 Denali cluster troubleshooting question
Hey GM techs!
Not the typical stepper motor failure.
A relative has an 04 Denali and the cluster has an intermittent total failure. No LCD readout, no gauges move. Will work for a day, then not. Was out for a few weeks recently. It was inop when I started looking at it today.
Pulled the cluster, opened the back, took a peek at the back of the circuit board and didn't see any obvious solder cracks at the connector pins.
Found this wiring diagram online; http://www.justanswer.com/chevy/36yc...e-cluster.html
I'm guessing the power/ground is the same in this diagram as it would be for the Denali.
I have constant 12v @ B11, switched 12v @ B9 and ground @ B12
The serial data lines show a flicker of A/C voltage (<1v) when the key is switched on (I consider that normal)
Cluster did start working again after I called it a day and plugged it back in. Stayed working thru a few key cycles and the car left.
I'm thinking that something on the power supply in the actual cluster is taking a dive, but I want to make sure I'm not missing something on the vehicle side.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
