01-13-2013, 10:44 PM | #1 |
c5 brakes into a 63
Is there any way of putting a c5 caliper set up front with out having to buy control arms? Can a bracket be made or sold already to use with a hub? If so who make them.
01-13-2013, 11:42 PM | #2 |
Re: c5 brakes into a 63
Only way i know is to do a 73-87 spindle swap and a kit like http://67-72chevytrucks.com/vboard/s...d.php?t=390979 or something close to it http://www.mcgaughys.com/bigbrake.html those brakes are 13 inch rotors 2 piston calipers which is about what the standard c5 brakes are.Or check out http://www.abspowerbrake.com they have a few brake options for your truck too.Or another place http://www.classicperform.com/
01-14-2013, 12:45 PM | #3 |
Try kore3.com
1972 Cheyenne (LWB now a SWB) |
01-14-2013, 10:59 PM | #4 |
Yeh, I think I will give Tobin a call. I got to order some hoses. I just wanted to see if any had made some brackets with a hub type set up instead of buying a set up.
01-14-2013, 11:18 PM | #5 |
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
01-16-2013, 06:09 PM | #6 | |
I'm just glad to be here!
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
