Alright since the stock dash speaker on the 60-66 Chevy's were square, what is a good speaker dimension to put underneath the dash? I'm ordering from retro sound and they have "universal" mounts. but I also plan on using a Dual voice coil speaker for more output.
what dimension speakers are you guys running 6x9? 5x7? 4x10? 6.5 inch circular speaker? |
Re: what dimension dash speaker are you running? I MUST KNOW!
I'm using one from LMC that is two speakers in one square mount, and includes 2 brackets to fit in the stock mounting location. You can find the same on from any vendor, and on ebay, etc. I used one in place of the one in my '71 pontiac (single center speaker to dual center speaker) and it sounds pretty damn good, no reason not to do the same in my truck. Haven't hooked it up yet, had it out of the box, build quality looks nice.
http://www.ebay.com/itm/64-65-66-CHE...sories&vxp=mtr
pretty much something like that. Not sure of wattage. Saves mounting headaches too. |
well considering i don't have any mounts from a factory speaker what do i do about that???
i need a mount. |
#5 | |
I'm more partial to the retrosound units, I'll give them a call tomorrow about what they think would work, they have ultra thin speakers that are dual voice coil and the output of those are AWESOME! |
![]() Join Date: Aug 2011
Brother's has a direct replacement "stereo" speaker part number CASDD00 for $39.99
Replaces the original mono speaker
http://s994.photobucket.com/albums/af62/ScottAz2/ |
I made a crappy little bracket out of scrap aluminum, and mounted what I believe was a 5x7 on it, it's not stereo but sounds decent.
![]() Posted via Mobile Device |
I used two 3 1/2" pyle tweeters installed using a stock speaker as a mounting bracket. Sounds good works good.
3.5" or 4" speakers are underrated. They get a lot louder than you think. I used a pair in my 68 and they sound great.
http://www.sonicelectronix.com/item_...ppa-42.9I.html ![]() ![]() There should be enough room under your dash for a small bracket setup
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
Kicker 4" coax
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
I have an old OEM speaker if you want it (it doesn't work at all, destroyed) but if you wanted to mount two speakers in it like those above, you could use it for that.
