Old 01-14-2013, 01:34 AM   #1
First c10
First c10's Avatar
Brake pedal height
Just replaced the power booster and m/c the PO updated to a power booster or just added a power booster. But when I took the booster and brackets off the firewall to install new and replace the boot. When I took the rod loose from the pedal the threaded rod end was only holding by 2 threads. Thank god for the jam nut being tight. So I tightened the rod ends about another 3/8". So now my pedal is close to the same height as the gas pedal please see picture. The m/c and booster is for a stock 72 I haven't finished the brake job on the front and rear yet but I want to know what the best height for the pedal ?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 01-14-2013, 09:22 AM   #2
JimKshortstep4x4
Re: Brake pedal height
When installed with power brakes the brake pedal height is close to the accelerator height. Outside of making another longer rod the height you have is normal.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 01-15-2013, 12:08 AM   #3
First c10
First c10's Avatar
Ok thanks I will adjust the rod as the last thing.
GO GO!!!
