Guage Lights - only speedometer LIGHT works
Hope the new years is treating you all well. It was 70 degrees yesterday so I took the 71 out for spin. At night, I noticed only the speedometer guage light worked. I would love to have all guages lit up.
Is it a bulb or fuse to fix these problems? Also, where is the fuse box in these trucks? If it is a bulb, where do I have to take apart guage cluster? Thanks |
Re: Guage Lights - only speedometer LIGHT works
Easiest way to replace the bulbs is to remove the cluster and change the bulbs, I've heard of people changinge the bulbs without removing the cluster but I've never tried it
Posted via Mobile Device |
If you have a long skinny arm you can reach in and change the bulbs. They are #194 and they sit in a twist in 1/4 turn base.
I have a short fat arm so I pulled the cluster out.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
I got mine out with the cluster in, skinny arms....
1972 Custom 10 Deluxe- original paint, interior- 72k miles http://www.cardomain.com/ride/2466316 Cheap, Fast or Good. Pick any two. 1990 Eagle Talon AWD 1991.5 W250 CTD 1992 Cushman Truckster- Haulster |
Petroleum User
I recommend pulling the cluster and replacing all bulbs at once and be done with it. 10 minutes max
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
If I were to take the time to pull the cluster, I'd take the time to check EVERY bulb. They are all 194s and can be easily checked by twisting the socket out and running 12 volts through each one.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Old member
Here is what the backside looks like. This is a factory Tach dash. The lights are the little black knobs you see. They are not hard to replace at all.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
very easy job and fairly quick
![]() Join Date: Oct 2009
Andy posted a great ref pic so you know where to put em. I normally just pop the cluster out as far as it will go without disconnecting anything (not very far) and then reach in behind (from below dash) and in from above (between dash and cluster that is pulled out slightly) to swap em.
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Mine doesn't have ac so it was easy without pulling the cluster, also skinny arms helped
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
