Airbag guys have any comments?
I'm installing air bags on my 65 C10 and then doing my buddies 66. I've researched and think I have it figured out. Here's a run down. Comments and pictures if you've done air bags yourself are always appreciated.
I'm doing this: Remove the bed. 8" step notch Rear bags (2600) mounted directly to the frame (notched for air line) and mounting directly to the trailing arm. No cups or plates. Tank (5gallon) and compressor (Viair 444c) mounted to frame or custom cross-member Compressor wired with 4 gauge wire Air system plumbed with 1/4" line Reinstall bed (notch bed floor or raise it) Controlled by Air Lift dual needle manual switches under the dash Font lower control arm cupped with 2600 bags mounted to upper control arm by a plate Questions: Will my tire (235/75R15) fit in the front wheel wells? Will I need to change my shocks? How deep can my a-arm be cupped? |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Airbag guys have any comments?
You need drop shocks, rear shock relocators and an adjustable track bar.
(at a minimum)
Thanks lolife99
I forgot the adjustable track bar. Also want to mention I am not doing drop spindles or front cross-member at this time. |
C/10 junkie
Would def like to see the install
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
Everything sounds close to mine minus the big notch in the rear. On my front lowers I just boxed tem flush with the lowest point and I run dominator 2600's up front and Firestone 2500's rear. I have twin 3 gal tanks and a smaller compressor wired with 8 ga wiring. Sounds like you got her figured out.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Thanks shortbed70
I was thinking the 8" step notch would leave me room to go lower later. What wheel/tire are you running? Did you alter the front inner fender? |
i went the same route as your thinking, except i ran drop spindles and a simple c notch..i made shock relocaters for the front and back. so no new shocks were needed for me. heres some pics of the stance and also my mods to the inner fender.
#8 | |
Thanks scum1, that fender picture is a great help. Does the tire ever rub or is that plenty of room? And does your c-notch bottom out?
Yeah shortbed70, gotta think ahead. I would rather not tub the fender but if I have to scum1's picture looks easy enough. I like the size wheel and tire I'm running.
You and your buddy have some cool trucks already, I'm pretty much going to do the same thing with my truck, I would like to see your build thread if you make one. Cool you're into bikes too what is that a cb? Are you going to chop it cafe it or leave it stock?
Posted via Mobile Device |
I like it.............
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
#13 |
Scum, have any details on the gas struts for your hood?
#14 |
i added some aftermarket bumpstops on my lcas to prevent a FULL drop, for safety reasons, so nothing rubs on the front when aired out, assuming the wheels are straight
![]() as for the rear i have found sort of a sweet spot that rides low without bottoming out on the bumpstops, however i sometimes drop the a$$ all the way and cruise too..i chose not to got for the big notch just cuz i like having a fully functional bed, minus the 1 inch raise on mine.. the hood shock idea i stole from member coulter on the forum ![]() i got tons of pics so let me know if you guys wanna see something. |
#15 |
oh ya and what kind of bike is that in the background im a fan of the xs650s, this is one i built about 3 years ago..fun as hell
#16 |
subscribed
![]() I'm going the same route on my 66 as scum Super stoked about getting this thing down low And that looks like an old Honda CB I've got a couple 750's I've bobbed out and others turned cafe racer But these Chevy trucks are my new found love Posted via Mobile Device
'66 c10 LWB fleetside 250 I6 3 speed on column '65 c10 LWB stepside 350/327 3 speed hasn't moved in 10 years. Just rotting away ![]() |
#17 |
I did same as u with a dual compressor setup and drop spindles. My wheels are the same size on an 8" rim and fit in wheel well when aired out just don't turn or else you'll need fenders. Bout an inch clearance from inner fender. I'm planning on z ing my frame so ill have to tub my inners. If I were u I'd do drop spindles while your in there. I did same as you are planning and wasn't gonna do spindles after the air ride was installed it wasn't low enough. So tore apart front end again and did spindles and disc brake kit and put 3" blocks on trailing arms. Has a nice stance now but I'm addicted to being lower
#18 |
Chevy Only Tx
Keep us posted, bet it will come out clean
Chevy Only Tx......... |
#19 | |
#20 |
#21 | |
#22 |
nothing fancy just the standard brake kit, couldnt afford big brake kit. i believe they are 11" single piston caliper
#23 |
nice any updates
project 66 flat n low ![]() |
#24 |
Very kewl thread. I just bagged the front end (rear has been done for a while now) and want to go a bit lower - 3" max. This gave me a few kewl ideas. Thanks!
..............................._________ ......___________//___[[___{\ _____ ...../__(_(O)_)___/____/____/_(O)_/ 1964 C20 Long Stepside 3 Door Crew Cab - Armbruster-Stageway Conversion Y2K INDN Chief "ONE OF A KIND, NOT ONE OF THE CROWD" Aug 2010 - Front end frame cleanup & engine swap done!!! June 2011 - Rear end bagged Sept 2011 - Rebuild motor top end Sept 2012 - Parked and slowly working on it. Aug 2013 - Front end bagged - finally! Aug 2014 - Stepside swap conversion done. Finally ready to start bodywork! Have a few KEWL ideas... Here is my build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=335427 |
