K10 spring hanger
what is the difference between the 4 wheel drive rear hanger and the 2 wheel drive ones? height difference? the forward rear spring hanger is rusted through on my k10. i have a c10 frame but its barried in a snow bank and i dont want to dig it out if they wont work
85 swb c10 6/6 drop 83 c10 bagged and sfbd project |
Re: K10 spring hanger
Yes, they're different heights.
The 4x4 rear spring hangers (both the rearward & forward ones) extend farther down from the frame than the 2wd hangers. |
if i run the 2wd hangers, could i compensate by doing a shackle lift in the back to level it out?
Since the rear shackles run from the spring hanger up to the spring, I don't think it's even possible to do a shackle lift on these trucks.
You probably could compensate for the height difference in the 2wd spring hangers by using some lift blocks between the spring & axle. Or better yet, some higher arch lift springs. |
i don't wanna run blocks, and new spring arent in the budget at the moment but i might have to save some extra cash
You could do a shackle flip to bring it back up.
Why couldn't he do a shackle flip? but on the question a shackle flip raises the truck 4in so hopefully someone knows the difference between the 2wd and 4wd hangars because if they're say 2in different, is that 2in lift going to be worth it?
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
ORD has 2.5 shackle flips
