Old 01-14-2013, 07:31 PM   #1
Your41Plague12
Your41Plague12's Avatar
Wiring woes, manual tranny wiring to automatic
Ok here's my deal. This is kind of confusing, so bear with me. I bought a cab for my truck, it's from an 84 C10 with an SM465, the truck it's supposed to end up being is an 83 GMC K2500. I am using the wiring harness from the C10. How do I make this work with my automatic column, i.e. neutral safety switch and such? What will I do for reverse lights, as well? The harness is stock, and relatively uncut. The only cut wires were the ones for the rear of the chassis. Thanks!
Steve
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 01-14-2013, 07:51 PM   #2
ray_mcavoy
Re: Wiring woes, manual tranny wiring to automatic
Check the wiring diagrams that hatzie posted at http://67-72chevytrucks.com/vboard/s...d.php?t=545416 to be sure, but I believe the cab/under-dash harness in these trucks is the same for all transmissions.
The manual trans will have a clutch safety switch that prevents the starter from cranking unless the clutch pedal is pushed all the way to the floor. I think you can simply unplug the connector from that switch and plug it directly into the auto trans neutral safety switch.
The manual trans reverse lights usually have an extension harness that runs from the under-dash harness down to the switch on the trans. I think you can simply unplug that from up under the dash and plug the reverse light connector into the auto trans reverse light switch (which is combined in the same housing with the neutral safety switch on the auto trans steering column). The two plugs (neutral safety & reverse lights) are shaped differently so each one will only plug into the corresponding spot on the switch.
ray_mcavoy is offline   Reply With Quote
Old 01-14-2013, 08:01 PM   #3
Your41Plague12
Ok, so basically all the wiring should be in the manual transmission harness to make the automatic work? It's plug and play? That's great news. I tried looking through the wiring diagrams, but I'm not much of an electrical wizard.
Steve
Old 01-14-2013, 08:09 PM   #4
ray_mcavoy
Yes, it should be pretty much plug and play ... so long as the wires are long enough to reach to the auto trans neutral safety switch and I think they are.
For the clutch/neutral safety start switch you're going to be looking for a pair of fairly heavy gauge wires (yellow and purple) that go into a somewhat square shaped plug. And for the reverse lighs you're going to be looking for a pair of lighter gauge wires (dark blue and light green) that go into a rectangular shaped plug. Both of these should be located in the under-dash harness somewhere close to the steering column.
