Wiring Harness
I was talking to my mechanic regarding wiring harnesses and he said that he has always gotten them for about a couple hundred bucks. From what I've seen they always seem to run for a lot more than that, at least for our trucks. I searched Painless' website and saw it up there for $700. Is there something I'm missing or are they just that much money these days? It is definitely on my agenda to address at some point but if there is something I am missing and I can get it for much less, it may get moved up on my list that much further.
Re: Wiring Harness
Yes can buy cheaper kits ( universal ) not direct wiring. That's not always good depending on the installer, will it look factory no.
It's not a place to cut corners, cheap is fine but having a fire isn't worth a few bucks.
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
#3 | |
Re: Wiring Harness
Posted via Mobile Device |
#4 | |
2WD Jimmy
![]() Join Date: Mar 2005
Re: Wiring Harness
Call Wes at Classic Heartbeat in Wash State. He is the man, and will help you alot with advice. He is a well known and respected vendor here. |
I agree with getting the Autowire Kit....it's awesome..Painless was good on my Scout...but knowing now what I do..I would have gone American Autowire on all my vehicles.
1972 Chevy Blazer ![]() Check out my build: http://67-72chevytrucks.com/vboard/s...d.php?t=560741 |
Re: Wiring Harness
I have bought a couple of harnesses from LMC for my trucks. I don't know who makes them for them but they were excellent. All the terminals, plugs, and ends were on the correct colored wires. Plug and play. I have used M & H harnesses on my GTO and they were also excellent. I would never buy a harness that didn't have the correct factory colored/striped wires, pre-installed plugs and terminals, and factory-type taping.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Re: Wiring Harness
Thanks for all of the advice guys. I haven't put in wiring harnesses before and appreciate the direction on which to check out. I will look into them both.
Re: Wiring Harness
I have used M&H, and cant complain about any of it. Like Savage said, all plug and play with the correct ends and wire color
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Re: Wiring Harness
American Autowire is what I like. Put one in a friends '67 Chevelle a few years ago & just bought another one last week for my Blazer. Comes with great instructions & knowledgeable tech support, that actually answers the phone!
The vehicle specific kits are more expensive (little over $500), I just got the universal Builder 19 for $356 from Summit for Blazer. It is just as detailed as the specific one was for the Chevelle.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
Junior Member
Re: Wiring Harness
I picked up a painless from Summit for $389 for my burb and had it installed by a shop and there were no complaints.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
#11 | |
Re: Wiring Harness
What kind of shop did you have do the install? I have tossed around whether I want to tackle this project myself, but I wasn't sure what kind of shop did that kind of wiring. A stereo shop or something perhaps? |
Junior Member
Re: Wiring Harness
Painless 10206 http://www.summitracing.com/parts/prf-10206, they price matched this site http://www.streetsideauto.com/p/painless-wiring-10206/
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 02-11-2013 at 03:23 PM. Reason: add info |
#13 | |
Re: Wiring Harness
#14 |
Junior Member
Re: Wiring Harness
It was a Custom Car and Truck Shop.
#15 |
Re: Wiring Harness
Gotcha.. well I'm still mulling around with whether I want to tackle it or not but I'll have to dig around and see what's available if I want to farm it out. Thanks for the help and info though. You saved me a few hundred bucks. I really appreciate the help!
#16 |
2WD Jimmy
Re: Wiring Harness
Warning... if you are going to do it yourself, get the American Autowire kit. It has everything. Did I mention everything?
You will be able to do it yourself, and save $1000 or more on installation. You will Not get that with Painless. |
#17 |
Junior Member
Re: Wiring Harness
Your welcome. I paid $900 for installation. So for a total rewire I was just short of $1300.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 02-11-2013 at 08:22 PM. Reason: add info |
#18 |
Re: Wiring Harness
I agree with Tom. Painless wiring I hear is not... Ive heard good things about American Auto Wire and it takes little to no knowledge in the auto electric department to install.
71 K5, AC/Tilt, 4" lift 33" tires 5.3L/4L60E/NP 205 (Under Construction) 05 Dodge 2500 4x4 5.9 Cummins (Daily driver) "Common sense is not so common" My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=555879 |
#19 |
Re: Wiring Harness
Well I ended up going with the Painless. I've been looking/asking around about harnesses and really got a mixed bag of responses. A lot of people loved the Painless kit and had no issues with it (installing it on their own or otherwise), but I also had several people to go with AAW kit. The kit came in yesterday and looks to me to be pretty straight forward. Every wire is color coded and labeled with where it goes every foot or so.
I go back and forth all of the time on whether I want to tackle it myself, mostly out of apprehension that I mess something up. I think I will likely give it a shot and if I get stuck, enlist help at that point. I have wiring experience with electrical and telecommunications but not with vehicles. |
