View Poll Results: Where to place Air Bags
A) Behind Axle 2 14.29%
B) Over Axle 2 14.29%
C) On trailing arm in stock coil sping location 10 71.43%
D) Farther forward on trailing arm 0 0%
Voters: 14. You may not vote on this poll
Old 01-14-2013, 10:35 PM   #1
jmsaunders
jmsaunders's Avatar
Question air bag placement
I apologize if this has been asked but I searched and couldn't really find an answer. I have been side tracked on my 54 project and I'm about ready to tackle the suspension on it now (had to save up money lol). Anyway I've decided to weld in the crossmember and trailing arm set up from a 67-72 C10. I also plan on installing air bags (firestone 9000 sleeve bags 1500lb, 1/4" port). My question is for best ride quality where should I place them? I have a 72 C10 that I do my hauling with so losing load capacity is not a major concern.
A) behind axle
B) over axle
C) on trailing arm at stock coil spring location
J'aimi
54 Chevy 3100 5.3/4L60E (Plan to make summer daily driver)
54 Chevy 3600 "Destiny" future project (Plan to build for my daughter)
72 C10 current daily driver
74 Nova Son's DD (His 1st car, we had to start him off right)
00 F*rd Expedition wife's DD (She's the trader in the house and doesn't drive a GM )
jmsaunders is offline   Reply With Quote
Old 01-14-2013, 11:19 PM   #2
jimmydean
jimmydean's Avatar
Re: air bag placement
From my understanding, the best ride comes from the stock location, but I've never had a truck with bags over axle, just heard the ride is worse.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-14-2013, 11:21 PM   #3
shawno72
C/10 junkie
shawno72's Avatar
Interested as well.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 01-15-2013, 12:59 AM   #4
cubber
A) behind axle
B) over axle
Stock location, definitely. That is where your suspension was built to take the weight. I have seen them put further forward to gain a higher lift, but that was for trucks built to play with. If you choose the proper bag (one that will be at your desired height while at an air pressure that creates a firmness you are happy with), you can put a good set of shocks on that have been set at the proper angle, and cruise along smoothly!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 01-15-2013, 11:34 AM   #5
PBFAB.COM
PBFAB.COM's Avatar
Since the F9000 Rolling Sleeve bag is designed to be run at a 1:1 ration, it will perform best mounted directly off the axle tube. You do have your choice of making the bag bracket mount directly off the front of the axle, on top of the axle, or directly behind the axle.
Packaging and space will dictate where you end up mounting it. If you mount it off the front, you will get slightly more lift but will lose a negligeable amount of load capacity. If you mount it directly on top, you will maintain both load capacity and specified lift. If you mount it off the back, you will have slightly more load capacity, but will lose a negligeable amount of lift.
I always mount them directly off the back side of the axle and outboard of the frame on the C10 trucks whenever possible.... but depending on what size tires and wheels you run, you most likely won't have the room to put them outboard on your 54.
I have run them in front and behind on the 47-54 trucks with great results.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
