01-14-2013, 11:31 PM | #1 |
How does the steering wheel horn button mount?
I just replaced my steering wheel with a different stock one, and I can't figure out how to put the internal horn parts back together so the horn works? There's a backing plate with 3 holes and some slits, a cup shaped metal piece, a plastic disc and 3 screws. There's this spring mounted pin that pokes up through the steering wheel. I think this is for the horn. I just can't figure out exactly how to mount it up so the horn will honk? I know as I try to figure it out, the horn honks like crazy lol
Posted via Mobile Device |
01-14-2013, 11:45 PM | #2 |
The Older Generation
Re: How does the steering wheel horn button mount?
Here is a thread that I posted some info in see if it helps. http://67-72chevytrucks.com/vboard/s...highlight=horn LockDoc
01-14-2013, 11:50 PM | #3 |
Lol...sounds like me a couple months ago...I had to make my neighbors mad with all the honking, then I figured out if I disconnected the battery, it wouldn't honk so much haha
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
01-15-2013, 12:02 AM | #4 |
Old member
Ok I'm going to try and explain. The spring goes in the little hole to rest on the cam that has the copper ring around it. Then the metal spring plate that has the holes in it then the metal cup then the plastic with the screw holes to tighten it all down. That's from memory when I did mine a few weeks back.
Is this the parts you have?
01-15-2013, 01:06 AM | #5 |
I wouldnt think it would be too difficult
1971 GMC Sierra 1959 GMC 100 |
01-15-2013, 01:22 AM | #6 |
01-15-2013, 01:25 AM | #7 | |
That's helpful, but I've still got a couple questions. That dial with the 3 holes that goes in first has an additional small pinhole that I don't see on the pic. Which way does it go? Also, how far do the screws go in? All the way? Posted via Mobile Device |
01-15-2013, 01:27 AM | #8 |
I was being sarcastic man and I am not a Kid Lol
01-15-2013, 01:29 AM | #9 | |
01-15-2013, 01:30 AM | #10 |
Good Luck though
01-15-2013, 02:45 AM | #11 | |
01-15-2013, 06:26 AM | #12 | |
Old member
The first picture has the plastic ring with the three screw holders up side down and yes they go all the way in just hand tight not torqued down. Here is how it should go. Top is 1 middle 2 bottom last.
01-15-2013, 10:54 AM | #13 | |
LockDoc
01-15-2013, 11:34 AM | #14 |
Does this help?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-15-2013, 12:13 PM | #15 |
Hi Vince, The only problem with that illustration is that the small parts shown in the big box are not in the correct order. LMC is aware of it but won't change it. Here is what it should look like... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 01-15-2013 at 12:34 PM. |
01-15-2013, 12:21 PM | #16 | |
01-15-2013, 12:31 PM | #17 | |
I just added a corrected picture to my previous post. #9 in the picture starting at the bottom of the box is a spring, aluminum pin and a plastic keeper that holds the spring and pin in the tower/nipple on the cancel cam/horn contact. It pushes in and turns to lock it in the tower/nipple. LockDoc
01-15-2013, 01:34 PM | #18 | |
01-15-2013, 01:37 PM | #19 | |
01-15-2013, 02:11 PM | #20 |
Old member
I used the orignal spring in mine and it's all one piece. It has the little metal cover made to it. It also will come out if you want it to. I had to stretch the spring on mine to make it work good.
Oh when working on the horn just unplug it from the horn in the front driverside fender. That way you can see it making contact as you work but no sound.
01-15-2013, 02:53 PM | #21 | |
I can't be sure without seeing a picture of it, but probably.. LockDoc
01-15-2013, 03:47 PM | #22 |
Ok guys, I still need some help. I installed the pieces, but I can't get it to honk the horn, unless metal touches the center bolt. If I put it all together as it appears to go, it doesn't honk the horn when I press the horn button. It's like the current is carried through the nipple and the center bolt. I don't get it.
Here's a pic before installing anything but the steering wheel and bolt Here's a pic with just the disc. I noticed it appears to fit best when turned so the concave part faces up, so that it clicks when pressed. I assume that's right. I tried it the other way too, and it still didn't work, and didn't feel right This is with everything installed Posted via Mobile Device |
01-15-2013, 04:16 PM | #23 |
thanks for the correction LoKDoc
01-15-2013, 04:57 PM | #24 |
hey guys i know how everything goes and in which order its just that my 67 has a very loose horn. if i tightne the three screws then it get nice and tight but then the horn doesnt work... so if i loosen it it still doesnt really work. so i know for sure that the cup is correct and the little plate is correct to but the plastic ring might be wrong? it has very deep "sockets" and i noticed there is one style ring that doesnt have deep sockets which one do i use for a 67 68 sterring wheel?
01-15-2013, 06:28 PM | #25 |
Ok, now I'm wondering if the reason it isn't working, is that my truck is a '69, but I'm installing a 67/68 steering wheel? Are the horn contact parts different for 67/68 wheels?
