Old 01-15-2013, 01:44 AM   #1
ScottH
ScottH's Avatar
250 6 cyl engine problems - need some input
Recently bought a 72 C10 with a 250 3 speed drive line. When I bought it the exhaust leaked really bad, thought the doughnut was shot along with the tailpipe. Found out the exhaust manifold was badly cracked, so replaced it.
Got it started after replacing the exhaust manifold and it ran really crappy.
Rebuilt the carb and still running lousy. Checked timing and it would only run half way decent way advanced. Decided to do a compression test and found cylinders 5 & 6 very low (90 & 60). The oil shows no sign of water in it, except that it is over the full mark.
I'm thinking a blown head gasket. I just dont want to put a lot of work into it only to find out the head or block has problems. As it is I would have to replace the carb and still not sure about the timing issue (checked TDC was correct, plug wires correct, etc.).
Any ideas or suggestions what to do next?
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 01-15-2013, 07:30 AM   #2
zeeklu
Re: 250 6 cyl engine problems - need some input
When I got mine(67 k10 292) it had really low compression but ran pretty good. It could just be worn out. I had a lot of problems with vacuum leaks where the intake meets the head. How did it run before you replaced the exhaust manifold? Chris
zeeklu is offline   Reply With Quote
Old 01-15-2013, 10:43 AM   #3
ScottH
ScottH's Avatar
ran rough, figured it was the exhaust leaks or carb.
I've got to decide on whether to fix/replace the 6, or just put in a small block.
I was planning to go sbc eventually, but wanted to run it with the 6 for a bit.
I have a new create 350 and a T5, so may just bite the bullet and install them.
Either way it wont be till spring now.
Old 01-15-2013, 11:27 AM   #4
68gmsee
Active Member
68gmsee's Avatar
As I mentioned in a post on the engine and drive forum, don't spend money on it if you are going to swap it out anyway. Use it to help with the swap cause you won't recoup the money.
However, if it's not burning oil and you want to run it for a while just replace the head gasket. It's a one day job.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 01-15-2013, 11:39 AM   #5
Longhorn 70
Longhorn 70's Avatar
had a 64 that acted that way....LOW power and lumpy. I pulled the plugs and ran a compression test. found that there was a leak between 1 and 2 holes. replaced the head gasket and drove it till I sold it. Ran great after that and I was able do the work for about $50.
if you can't do a compression test, just bring each cylinder up to top dead center on compression stroke. put a tight fitting hose in the cylinder and blow in compressed air....You'll hear where it is leaking from.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 01-15-2013, 11:51 AM   #6
ScottH
ScottH's Avatar
Thanks guys.
Longhorn 70, great idea. I will fill the cylinder with compressed air and see what happens.
Why didnt I think of that? lol.
Scott
Old 01-15-2013, 12:07 PM   #7
BMERDOC
BMERDOC's Avatar
A leak down test should always be performed in concert with a comp test.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 01-15-2013, 07:21 PM   #8
ScottH
ScottH's Avatar
Thanks to all......looks like at least 2 bad valves, and possibly head gasket.
Old 01-15-2013, 08:26 PM   #9
BMERDOC
BMERDOC's Avatar
So are you gonna keep it or junk it in favor of the small block? It'd be nice to have that small block in before warmer weather.
Nick Carter
Old 01-16-2013, 01:45 AM   #10
ScottH
ScottH's Avatar
Still deciding, kinda depends if I come across a cheap 6 locally.
