Old 01-15-2013, 01:53 AM   #1
Aarons72
Aarons72's Avatar
Will this Air Ride kit work on a burb?
I put this same thread on the burb side of the forum but I thought I might get more info over here on this side...
Anyway, I've been looking for some bags for the front of my burb...came across this set fairly close to me. He said he we do 700. He says he paid around 1500. It was intended for a 67 swb...he says he installed the mounts but then took them off and sold the truck so the rest of the kit is brand new. He bought it several years ago and cannot find the booklet of info so he couldnt give me a lot of details...by looking at this kit can anyone say if this setup would work for a burb or not? Or could anyone give me some advice on what questions I need to have answered about it?
Reduced to $800.00, Air Ride system complete with Four Bags, Air Tank, Gauges, Compressor, Mounts, and all Lines and Hardware.
He said he would give it to me for 700
Aaron Anderson
*1971 GMC Burban - Daily
*1962 Nova
Aarons72 is offline   Reply With Quote
Old 01-15-2013, 03:49 AM   #2
andrewmp6
Re: Will this Air Ride kit work on a burb?
Ask what brand the bags and valves are and where he bought them.If he says airbagit.com or chassistech pass on it.
andrewmp6 is offline   Reply With Quote
Old 01-15-2013, 02:25 PM   #3
jimmydean
jimmydean's Avatar
It looks like a plug and pray kit from airbagit, not the best option.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-15-2013, 02:54 PM   #4
Aarons72
Aarons72's Avatar
Ha ha . That bad huh? Ok well Im glad I asked. Keep the comments coming
Aaron Anderson
*1962 Nova
Old 01-15-2013, 04:31 PM   #5
jimmydean
jimmydean's Avatar
When I bagged my '69, I found a partial kit on ebay with a compressor, tank, bags, and a few valves. I bought fittings, line, more valves, pressure switch, gauges, and a switch box. It took a little while because I was on a tight budget, but I think when it was all said and done it was about $600 + the bag brackets for the front.
The only real issue I had was the tank was 7 gallons and I only had a single Thompson compressor. So I wired a hard switch to turn on the compressor and would shut it of manually before it burned up when my tank was too low and trying to fill it to 200psi.
Talk to one of the site vendors. You could go with a manual valve setup, or just put together a very basic kit you can expand on later.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-15-2013, 05:48 PM   #6
Pro Performance
Pro Performance's Avatar
We would be happy to help with an air bag kit. You can go with a manual setup which would save some money without having to sacrifice quality components. As for the suspension components, you do want to go with shock relocators, good bags & shocks. Just give me a call and can go over the details with you.... or even send me an email at travis@azproperformance.com
- Travis
480-420-8175
Pro Performance is offline   Reply With Quote
Old 01-15-2013, 10:28 PM   #7
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
i would stay away from that kit your looking at.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 01-16-2013, 02:42 AM   #8
Aarons72
Aarons72's Avatar
Ok thanks - nough said
Aaron Anderson
*1962 Nova
Old 01-16-2013, 04:57 AM   #9
andrewmp6
Yeah good idea on passing it,Talk to pro performance and a few of our site vendors they all can get you name brand stuff with a nice discount.I have yet to see a bad vendor on here they all go above and beyond with customer service.Is it going to be your first air ride system?Its kinda like a drug once you have it you want it on every thing you drive lol.
