Old 01-15-2013, 06:11 AM   #1
monolith
Zero Albedo
monolith's Avatar
Any reason to not use driver side drop?
Researching converting my 65 GMC 1 ton panel to 4wd.
133" wheelbase-I can run a divorced transfer case, correct?
Any reason to not gather a driver drop np205 and high pinion Dana 60?
I'd be using the truck as a back country camper.
Thanks for any help-still trying to wrap my brain around this 4x4 stuff.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 01-15-2013, 06:50 AM   #2
b454rat
Re: Any reason to not use driver side drop?
If you can find a 78/79 Ford high pinion 60 in your area go for it. Even out here they are still expensive.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-15-2013, 02:25 PM   #3
OrrieG
OrrieG's Avatar
Might be conflicts with clutch and brake stuff if you have that frame mounted? I think the fords used hydralic clutch operation to get the linkage out of the way???
OrrieG is offline   Reply With Quote
