LMC Seat Belts barely poke through the bench seat
I think I have the thicker foam seat but is this normal or are there extensions. It's a bit of a pain. Thanks.
Also, if somebody has a pic of the way the receiving belt with the female end bolts to the floor it would help. I just did mine so it would have the most reach, facing up. |
#2 | |
Maintenance Man
Re: LMC Seat Belts barely poke through the bench seat
No single fastener has ever been the same size/fitment as the factory fastener, no sheetmetal piece has ever fit even close to correctly. I take that back. The stock height coil springs for the 71 LWB C10 fit fine, as did the replacement rubber sway bar bushings, and the I/O tie rods. Everything else has been a crap shoot. |
Yeah, that has been the case for me as well. Bolts were not the right thread, had to go buy them as well.
Guess I have been lucky with LMC have not had any problems with there products everything has fit fine.
Posted via Mobile Device |
